am 09.02.2019 15:01
I just got my new router today.
However, I cannot use wifi with it.
Internet connection with LAN cable is okay but, Wifi cannot be used... (I followed the instruction correctly...)
When I reset the router I can access to the wifi just few seconds...
Please solve this problem...
regards,
am 13.02.2019 08:43
Hi ninzalsj,
Since the system says you have already booked the WiFi option, I'm closing here.
Regards
Wallace
am 09.02.2019 15:07
am 09.02.2019 15:17
Actually, I cannot remember I added the wlan option or not.....
Do I need to add wlan option if I want to use LAN cable and wifi in same time?
regards,
am 09.02.2019 15:23
yes that is so.
am 09.02.2019 15:42
ah...okay.
Then, if I order that option today can I use wifi immediately?
am 13.02.2019 08:43
Hi ninzalsj,
Regards
Wallace
