Siehe neueste
Failure of establishing an internet connection after reboot of a rooter
TomHyphens
Dear support staffs,
Firstly, please forgive me for posting in English due to my poor German.
My cable internet often fails to establish the internet connection, after rebooting of the rooter.
Could you please give me some solution?
I happened to the trouble at leaset twice.
1st-time trouble
This trouble first occured on 20th of October, where:
the router had not been able to establish the connection for 2 days; and
then, suddenly the connection recovered for some reason.
2nd-time trouble
Today, 23rd of Octorber, after I turned off-on the router to arrange my room, the connection failure occured again, which connection failure has not solved yet.
What I did when involved in the troubles are:
- Changing a satellite cable (in 1st-time trouble) and
- Doing factory reset on the router (both in 1st-time and 2nd-time troubles).
The Error messages of the Event-log of the Fritz! BOX in 1st-time trouble are as follows:
- Internet connection IPv6 could not be established: No response from DHCPv6 server (SOL)
- Internet connection failed: Error reason: 2 (DHCPv4 no answer on DISCOVER)
- Internet connection failed: Error reason: 3 (DHCPv4 no answer on REQUEST)
After sudden recovery from the 1st-time trouble, I found the following message recorded on the Event-log:
The service provider has successfully established. IP address: XXXX: XXXX :: XX: XXXX: XXXX: XXXX: XXXX
Additional information :
In which state do you live? Please also send the zip code
Bayrn, Freising 85354
Which contract do you have? (e.g. internet + telephone 100)
Which modem / router do you use? (e.g. Hitron)
Fritz!box 6591 Cable YP
Do you use a loaner device from us or do you have your own device ?
I use a loaner device
How is your terminal with the modem connected ? ( LAN; WLAN; additional router; PowerLAN )
LAN, WLAN
Which browser do you usually use? (e.g. Firefox)
Chrome
Which operating system do you have on your computer? (e.g. Windows)
Windows, iOS, Android
Start and period of the disturbance  (e.g. since the beginning of April; only in the evening)
since 20th of Octorber
What measures were carried out by the fault hotline (available at 0800-5266625 for Vodafone Kabel Deutschland or 0221/46619100 for Vodafone West)?
After processing Netz-Assistent, you called me via phone call. But I could not communicate with your staff due to my poor German skill.
Thank you for your help.
Best regards,
TomHyphens
12 Antworten 12
Thomas
Moderator
Hi TomHyphens,
we will take a closer look at your connection. Please send me your customer number, name and address in a private message.
Then reply again here in the post.
Regards
Thomas
Netz-Assistent How To Hilfe !
#bleibtgesund
TomHyphens
Dear Thomas,
Thank you for your reply.
I sent you the required information via private message.
Please refer to it.
Best regards,
TomHyphens
Thomas
Moderator
Hi TomHyphens,
the data was unfortunately not complete. Please send the missing data and report back here.
Regards
Thomas
#bleibtgesund
TomHyphens
Dear Thomas,
I sent the missing data via private message.
Please confirm it.
Best regards,
TomHyphens
Moderatorin
Hello TomHyphens,
thank you. Some signals on your modem are out of range. Please replace the coaxial cable as a first step. If that doesn't help we can send a technician who can replace the modem if necessary. He will need access to the house installation, can you grant him that? Are there symptoms in your household that might be linked to Covid-19? Can the technician reach you under the mobile number that ends on 128?
Kind regards,
Alles Easy How To Hilfe !
TomHyphens
Dear Claudia,
Thank you for your message.
I already replaced the older coaxial cable with new one at the early stage of the series of connection troubles.
Yes, I can grant him.
No, my partner and I have no symptoms that might be linked to Covid-19.
We were subject to the second vaccination in the end of August.
Generally, the technician can reach us under the number that ends on 128.
However, I would like to tell you another number also
because the person having the number that ends on 128 is 10th-month-pregnant and about to give the birth.
Could you give me the link to a private message in order for me to tell you the other phone number?
Best regards,
TomHyphens
Moderatorin
Hello TomHyphens,
please send the alternative number via PM and reply here again so we can send the technician.
Kind regards
TomHyphens
Dear Claudia,
I have just sent you another phone number via Private message.
Best regards,
TomHyphens
TomHyphens
Dear Claudia,
I would like ask you to first send a new router, if it takes more or less time for your technician to reach us.
With a new router, we can see whether the connection problem be caused by the current router alone or by other factors.
In the night of yesterday (Nov. 12) I mistakenly turned off the router and soon turned on again.
The router, unfortunately, still (Nov. 13, 09:30 AM) does not work properly yet ...
Recentely the router has been in very bad condition, which adversely affect our jobs.
Thank you for your support.
Best regards,
Tomhyphens
