am 15.06.2021 21:35
Hello,
I've been trying to request a callback via Netz-Assistent but every single time upon completing the process it says that this feature is not available right now.
Ever since we signed the contract, the connection is way below the tariff we signed up for. Today's upload result is actually the highest in weeks (normally it's between 1 and 5), but download remains a fraction of the contract speed.
On few occasions I had to switch to a hotspot because of connection volitility - not exactly ideal.
I did try all the optimization steps, no visible effect. Issue persists with both WiFi and WLAN.
I'm using Vodafone TG3442DE. Also, it's a new building. Is it something that can be looked into remotely? Something with upstreams? Otherwise, I would really appreciate it if a technician could reach out.
am 16.06.2021 08:40
Hello Marcin_Jarosz,
in which state do you live? Are you connected via LAN or WLAN?
Greetings Moni
16.06.2021 17:24 - bearbeitet 16.06.2021 17:25
It's Berlin, zip 10115.
Speed test performed on a PC connected via WIFI, but it wasn't any different when I used WLAN.
Today's results:
am 17.06.2021 08:19
I would be happy to take a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Then please contact me again here, when you have sent me the data.
Best regards
Moni
am 17.06.2021 15:20
Hello,
PM with relevant details sent.
Kind regards,
am 18.06.2021 08:07
the line values are completely clipped.
Are you using the original cable and is it still plugged into the router?
Greetings Moni
am 18.06.2021 10:45
I connected it straight into the cable/fuse cabinet. There the cable was being divided into three (three wall extensions in the rooms) so instead of pluging it into an extension, I moved it to the "source".
am 18.06.2021 11:47
did you do it yourself or did a technician from us do it? The line values are just not in order. If the error is in your own wiring, then the technician will be charged here.
Greetings Moni
am 18.06.2021 15:23
It was a package, sent during the lockdown for self assembly - so no technician was involved.
Now I connected it with the cable fro mthe package, to the wall, can't say I see any significant difference.
am 19.06.2021 16:50
then I would like to ask a technician to reset the signal.
Please send me a PN with a current mobile number, the info if you can access the house amplifier and if there are signs of Covid-19.
After that please leave a short feedback here.
Best regards, Martin
