am 20.12.2017 20:37 - zuletzt bearbeitet am 20.12.2017 21:22 von Stephan
Hey, I'd really appreciate any response in English if possible.
My Easybox stopped working about 2 weeks ago (around 8th Dec) and the person on Support said he'd sent a new one.
I recieved the new one, and I always got stuck on the "Please plug the DSL cable into the dedicated DSL port on EasyBox" page with the "continue button" grey.
The other call said it would be this way till my router was activated 3 days after. So I waited and tried again, and still keep getting the same screen with no continuity.
The DSL is plugged in, I can't get any answers through support, and there's been no response to my ticket. Its also giving me the same screen with no progress if I try using LAN.
Can anyone help me with this? I have had no internet in 2 weeks and can't find a solution.
EDIT: moved to technical board
21.12.2017 18:03 - bearbeitet 21.12.2017 18:09
Hi GunnyG,
welcome to the Vodafone Coummunity!
Please try to reset the Easybox to factory settings. Thats how it works:
1) Use a pointed object (paper clip) to hold down the reset button (located on the back of the EasyBox) for 8 seconds until the LED lights flash.
2) Configure your Easybox with the modem installation code (MIC) via telephone.
MIC input via PC: Open your browser and enter "easy.box" in the address bar. Now enter the user name and password for access to the configuration interface. By default, the user name is set to "root" and the password is set to "123456". Start the configuration interface and log in. The welcome page will be displayed. Select "standard installation" and enter the modem installation code. Click on "Apply" to start the configuration.
3) The EasyBox reconfigures itself. This process can take up to 10 minutes. Important: Wait until the power LED is solid red. Note: It may happen that the power LED changes color several times. During this time, the device must never be switched off, otherwise it may be damaged.
4) The hardware reset is completed when the power LED, Internet / DSL LED, telephony LED and possibly the WLAN LED are lit.
Was this information helpful to you?
Best regards
Kira
am 21.12.2017 20:08
Hey Kira,
Sadly, no 😞
The router/process never recognises that the DSL is plugged in, and even when I try it with LAN I'm unable to get through the first screens. I'm never asked for the MIC.
I was given a ticket number more than a week ago and there's been no updates, is there a way for me to email/PM you my ticket number in case there's a bigger issue?
I don't know if there's a connection problem since one moment the net was working, and in just a moment it went off without any indication, and even on getting a new router from Vodafone the problem doesn't get solved. The entire process is more than 2 weeks without internet now 😞
22.12.2017 16:34 - bearbeitet 22.12.2017 16:39
Hi GunnyG,
please send me your personal Data (customer-ID) via PN and I´ll have a look at the status of your ticket.
Are you a Vodafone-customer in mobile, too?
Best regards and have a nice christmas time,
Kira
am 22.12.2017 17:11
PM'd you! Thanks 🙂
25.12.2017 13:47 - bearbeitet 25.12.2017 13:47
Hi GunnyG,
I´ll get back to you as soon as possible as I wrote you via PM.
Kira
am 19.04.2018 18:07
am 20.04.2018 15:35
Hi raymond1,
as I see you already have opened your own thread.
I will answer you there and close the thread here.
Regards,
Jens
