am 15.10.2019 03:47
The worst internet provider I've ever had. Every 2 hours my download speed could low down to 6 Mbps for 20 minutes. It does not matter which service you had (100Mbps, 200Mbps...) you will still face this problem all the time. Some times I have an expected speed, but if your work depends on stable internet do not use vodafone.
am 15.10.2019 10:53
Did you contact the support ?
am 15.10.2019 16:21
Did you check the speed by using WiFi or LAN connection? Lemme guess, you have used Wifi, am I right?
If yes, then connect a device by LAN and do the speed check again.
am 15.10.2019 19:36
Hi, thank you for your feedback.
I am using only LAN connection. Unfortunately, it is not a reason (
am 24.10.2019 03:11
Hi.
Yes. After 3rd attempt and waiting for 30 minutes I finally got support. I explain to him the problem. He said that from their site everything is good and he can not help me. He suggested to make an appointment, BUT (as usual, you should expect from vodafone) He said that I should pay 100 euro if the problem was on my site. I kindly asked him to explain the all possible cases, what does it mean 'the problem on my site' after all he just point me to the vodafone web site, without even give me a hint where I could find this information here on website. Interesting logic, isn't it? So if the problem would be on your site and you can not fix, will you pay me 100 euro 🙂 ? This is hell. No one can not help me here. If you just ask me to pay for an appointment I would do it. But without these tricks and games. Please, could someone help me here?
am 24.10.2019 09:52
Ich möchte gerne den Anschluss überprüfen. Sende mir dazu Deine Kundendaten (Name, Anschrift, Kundennummer, Geburtstag) in einer privaten Nachricht und gib dann kurz hier Bescheid, dass Du mir die Daten übermittelt hast.
Regards
Wallace
am 28.10.2019 13:28
am 30.10.2019 21:51
Hi JohnSnow,
the technician will call you to arrange an appointment.
Please keep us informed.
Kind regards
am 06.12.2019 22:49
No help at all. Internet does not work. And vodafone always tries to *** you. Do not use this provider!
am 10.12.2019 09:15
Hello, JohnSnow,
According to the last technician who was supposed to fix the problem on site, you weren't living at the current address. Apparently there's a problem with the LTE irradiation on site. Did you check if all cables are attached to the modem and the antenna socket?
Best regards Fred
