am 28.09.2020 11:04 - zuletzt bearbeitet am 30.09.2020 10:03 von Seb4sti4n
Hello team,
My DSL Speed is very low since two days. Below are the reference ID's for the speed test checks done using LAN
I use DSL 100, this is making me problem with work from home. Coudl you please check and update?
Regards,
Subrat
am 30.09.2020 10:06
Hello @ssahoo,
I cut the IDs from public. Please don't post it again here.
To check you contract, I need 3 IDs from different time. At least 6 hours apart. Please send me the IDs via private message afterwards. I will check it.
Best Regards
Sebastian
