am 17.10.2020 21:32
Hi, I have moved from the first to the second floor in the same building and I ordered a DSL move.
I chose the disconnecting date 19.10, and the connecting date 29.10.
However, on the portal "MeinVodafon", the date of disconnecting is shown27.10, but at this time I will no longer have access to this apartment.
Also, I don't understand why the technician needs to come twice if the disconnecting and connecting takes less than five minutes and will take place in the same building
am 19.10.2020 18:42
Hello @masyatsap,
the technician appears only for connection.
I see, that you write to Andre via private message to clarifying questions about the movement.
Unfortunately we cannot give an earlier date for connection. It is already the next possible date.
Best Regards
Sebastian
am 19.10.2020 19:11
Thank you for your answer.
Maybe you know, can I get extra GB for my phone?
am 21.10.2020 09:36
Hi masyatsap,
I saw everything went fine by PM.
Hoping you´re glad - so your thread can be closed?
All the best
Su
am 21.10.2020 21:50
Yes
Thank you for your help
