Menu Toggle
Aktuelle Einschränkungen
  • Mobil Es kommt zu Verzögerungen bei der Auslieferung von SMS, überregional/SMS Benachrichtigungen der Mailbox sind auch betroffen.
  • MeinVodafone im Web: Selfservice MeinVodafone im Web Registrierung/Hinzufügen von Verträgen.
  • Mobil: Aktuell kann es zu Einschränkungen, bei der Nutzung des Mobilen Hotspots bei iOS Geräten kommen.
  • Mobil: Bei Huawei Mifi Routern und Embedded Modulen, kann es zu falschen APN Einstellungen kommen.
Nähere Infos dazu findest Du im Eilmeldungsboard.
Close announcement
Störungsmeldungen Internet, TV & Telefon DSL
Siehe neueste
DSL relocation.
Highlighted
Hi, I have moved from the first to the second floor in the same building and I ordered a DSL move.
I chose the disconnecting date 19.10, and the connecting date 29.10.
However, on the portal "MeinVodafon", the date of disconnecting is shown27.10, but at this time I will no longer have access to this apartment.
Also, I don't understand why the technician needs to come twice if the disconnecting and connecting takes less than five minutes and will take place in the same buildingScreenshot 2020-10-17 at 21.29.06.pngScreenshot 2020-10-17 at 21.29.10.png
4 Antworten 4
Highlighted
Ex-Moderator
Hello @masyatsap,
the technician appears only for connection.
I see, that you write to Andre via private message to clarifying questions about the movement.
Unfortunately we cannot give an earlier date for connection. It is already the next possible date. Smiley (gleichgültig)
Best Regards
Sebastian
Alles Easy How To Hilfe !
Private Daten erfragen wir bei Bedarf
Highlighted
Thank you for your answer.
Maybe you know, can I get extra GB for my phone?
Highlighted
Moderatorin
Moderatorin
Hi masyatsap,
I saw everything went fine by PM.
Hoping you´re glad - so your thread can be closed?
All the best
Su
Netz-Assistent How To Hilfe !
#bleibtgesund
Highlighted
Yes
Thank you for your help
