am 21.02.2022 20:28
Speedtest von AVM
Datum Ping (ms) Download (MBit/s)
21/1/2022/22:16:54 95,77 10,973
21/1/2022/22:17:05 93,89 9,562
21/1/2022/22:17:27 93,14 16,713
21/1/2022/22:24:43 92,87 58,566
22/1/2022/22:32:37 91,73 47,908
23/1/2022/00:10:46 12,36 178,739
23/1/2022/16:11:00 98,23 9,798
23/1/2022/16:23:36 221,18 15,745
23/1/2022/16:25:16 90,9 13,891
23/1/2022/17:05:51 100,43 8,113
26/1/2022/19:50:07 88,39 191,046
26/1/2022/21:09:27 105,7 49,39
26/1/2022/22:17:22 11,51 231,711
27/1/2022/19:01:15 11,26 230,512
27/1/2022/19:14:55 11,76 234,912
27/1/2022/20:23:50 88,63 85,808
28/1/2022/21:48:41 92,03 96,088
28/1/2022/22:29:34 48,99 168,017
29/1/2022/20:59:07 156,66 23,683
29/1/2022/23:10:29 24,29 225,525
30/1/2022/14:33:08 89,24 25,504
31/1/2022/21:07:47 102,17 14,703
31/1/2022/21:53:00 94,98 144,635
1/2/2022/19:38:54 88,97 12,711
1/2/2022/21:34:17 101,1 3,729
1/2/2022/21:41:59 99,78 4,41
2/2/2022/17:08:42 14,61 231,571
2/2/2022/19:05:31 64 210,024
2/2/2022/20:23:19 99,77 5,507
3/2/2022/20:18:51 97,05 55,683
3/2/2022/22:16:44 75,24 60,129
6/2/2022/20:30:28 103,43 2,771
6/2/2022/21:28:48 98,51 4,272
7/2/2022/20:52:40 102,09 3,606
7/2/2022/22:13:39 80 108,835
8/2/2022/20:35:05 99,06 8,146
8/2/2022/21:51:17 96,22 3,978
9/2/2022/21:30:01 101,16 7,456
10/2/2022/20:25:01 98,74 12,466
10/2/2022/20:49:51 99,39 8,556
10/2/2022/20:59:19 102,46 6,011
10/2/2022/21:41:59 96,69 11,414
11/2/2022/21:10:02 100,79 5,7
11/2/2022/22:00:08 99,54 7,102
11/2/2022/22:13:24 97,53 6,686
11/2/2022/22:52:40 89,5 129,307
11/2/2022/23:10:26 18,62 218,391
11/2/2022/23:21:43 13,27 230,944
12/2/2022/20:34:09 81,63 17,445
12/2/2022/21:22:49 97,61 16,753
12/2/2022/23:34:03 12,09 221,856
13/2/2022/11:51:07 11,29 231,076
13/2/2022/17:07:33 87,11 236,206
14/2/2022/19:03:05 13,59 231,585
15/2/2022/21:08:14 100,53 4,905
16/2/2022/20:18:49 95,77 17,568
16/2/2022/22:14:00 96,16 9,454
17/2/2022/19:35:50 89,93 30,557
18/2/2022/22:04:40 84,82 8,376
18/2/2022/22:20:14 92,49 11,373
20/2/2022/11:51:37 11,43 230,738
21/2/2022/19:04:35 91 186,774
21/2/2022/19:26:21 90,26 84,283
am 21.02.2022 20:41
Hallo Liz250,
das klingt leider nach dem gleichen Problem das sehr viele Verbraucher*innen hier haben.
Offenbar lässt Vodafone seine Kunden hier vollkommen im Regen stehen.
In den beiden Threats kannst du weitere Informationen dazu finden:
Vertragl. zugesicherte Leistungen am Business DSL nicht annähernd erfüllt - Behebung in 3-6 Monaten!
Überbuchte Leitung? Abends starke Download Einbrüche
Weitere derartige Beispiele allein aus den letzten 2 Wochen hier wären:
Neben der Empfehlung am besten direkt mit einer Messkampagne über das Breitbandmessungs-Tool der Bundesnetzagentur als Beleg für die Performanceprobleme zu starten, sowie ein Ticket bei der Vodafone-Hotline zu erstellen ist meine dringende Empfehlung dich an die Bundesnetzagentur als zuständige Aufsichtsbehörde zu wenden!
Mit der Messkampner wirst du eine Rechnungsminderung bzw. eine Gutschrift, oder ein Sonderkündigungsrecht erwirken können.
An deinen Bandbreitenproblemen wird das aber nichts ändern.
Vodafone ist die Kapazität seiner Netze genauso bekannt wie die Anzahl der darin geschalteten Anschlüsse mitsamt der diesen Anschlüssen zugesicherten Mindestbandbreiten.
Offenbar nimmt man hier, zu Lasten der Internetnutzer, aus Profitgründen in Kauf wissentlich die vertraglich zugesicherten Mindestbandbreiten regelmäßig gravierend zu unterschreiten.
Dir als Endkunde sind dabei leider die Hände gebunden, da du auf die Gunst deines Providers angewiesen bist.
Daher sollte unbedingt der Weg über die Bundesnetzagentur eingeschlagen werden, da nur diese Behörde hier langfristig und für alle Kunden betrachtet effektiv etwas ausrichten können wird.
Hier noch der Link zum Beschwerdeformular der Bundesnetzagentur:
am 21.02.2022 20:52
Vielen Dank für deine Antwort.
Habe das Anliegen auch bei der Bundesnetzagentur gemeldet. Vielleicht meldet sich Vodafone noch zu Wort. Wir haben auch noch ein Handyvertrag mit abgeschlossen (GigaKombi). Möchte ungern Kündigen und hoffe das Vodafone schnell einen Lösung findet. Mal schauen...
am 16.03.2022 19:37
