am 18.10.2019 23:01
Hi guys,
So as of two days it says connected,no internet....green lights on wlan and dsl arent blinking so i figure it is a problem VFs end ..but noone else i know with VF is having problems...my German isn't so great but eventually i got through to someone who said a line was down for another 48 hours (from what i understood of the German)..i live in mainz..is there another possible reason or is this long outage normal?
Vielen dank!
am 19.10.2019 12:28
Hi Kiwi,
could you post please the system log and the internet-connection log of your dsl-box (e.g. Fritz!Box)?
am 20.10.2019 19:04
am 21.10.2019 10:40
Ah, do not know sorry why the image did not attach ..but basically it said DSL synchonising..there was only two lines...unlike the many on your image.
am 21.10.2019 11:19
Hello Kiwi,
your image did attach, no problem.
Did you register your modem installation code?
On the next screen you will be asked for the modem installation code, you have on the welcome letter from Vodafone. When this assistant ended positively you should have an internet connection.
am 21.10.2019 14:03
Hey Andreas,
I just got a callback from a VF technician from my enquiry last week and he said the same thing...I have to register my MIC....I guess I did, I recall using the code ..because it has been working for the last 4 months...but he said to reset it and sent a video how to do it...so fingers crossed it works!
Thanks for the help 😄
am 22.10.2019 16:16
Hi Kiwi,
how nice 🙂
May I close this thread then?
Kind regards
Heike
am 22.10.2019 18:51
Sure can
Cheers
am 24.10.2019 13:36
I've closed the thread. Many thanks to all contributors.
Best regards
WolfgangF
