am 05.09.2019 14:06 - zuletzt bearbeitet am 05.09.2019 15:02 von Matthes
So sorry for the English, my German is not good enough yet to describe the issue.
My Easybox 804 was already set up by my landlord. But when I try to connect, there is no internet service. I get the error message: "Please plug the DSL into the dedicated DSL port" - which is already plugged in, and it will not let me continue. I've tried buying a new DSL cable, connecting via LAN, and resetting the box to factory settings, but I just get the error message "No internet connection". I follow all the instructions listed in "Activating your Easybox 804" and "Easybox 804 Troubleshooting" on the Vodafone site, but still no luck.
The easy.box setup page says there is no IP address found. When I run diagnostics, I get the following error codes:
FC812
FC814
FC815
My landlord has already called Vodafone and they say there is no problem with the connection in the building or the area. I would really appreciate any help in this matter - I have not had internet for a week 😞
Thank you so much in advance.
Crystal
Edit @Crystal by Matthes (Mod): please pay attention to choose the correct board selection, moved from "Störungsmeldungen Internet, TV & Telefon Kabel"
am 08.09.2019 12:07
Hi Crystal,
I'm really sorry to hear that.
Please send me a private message with your customer or landline number and, if possible, the customer password. Then I can have a look on it.
BR,
Dany
06.09.2019 10:16 - bearbeitet 06.09.2019 10:17
Sorry, made a mistake - the error codes are FC811, FC814, and FC815.
am 08.09.2019 12:07
Hi Crystal,
BR,
Dany
