am 04.04.2020 18:32
am 10.05.2020 21:07
Marked the message as a solution by mistake.
The router is connected to both the power cable and coaxial cable, but it is blinking red. When the technician came and checked the cable, he said that the cable has signal but the router doesn't receive it for whatever reason. I think the same thing happens to this one, the new one the technician gave me.
am 15.05.2020 11:18
Hi adnedelcu,
did the technician also replace the power supply or just the router?
Now the router is online again. Did you change anything?
Best Regards, Manu
am 15.05.2020 14:32
The technician replaced both the router and power source. I got a new box.
Yes, since yesterday at around 20:00 the router started to have internet again. I didn't do anything to it. The router was only restarted once last week. I haven't done anything except wait for you to answer and solve the problem.
The router still has problems as it takes at least 20 seconds since I initiate the connection to get internet access and the internet is fluctuating a lot. I have a contract for 1000 Mbps, but on average I have around 200 Mbps, sometimes I get even less. I also get disconnected from services a lot (Skype calls, online gaming, video streaming).
am 20.05.2020 15:31
Hello adnedelcu,
do all these problems occur with a direct ethernet connection? Is the speed slow all the time, so even in the night? Are your devices capable of the 1000 MBit/s?
Kind regards,
20.05.2020 15:41 - bearbeitet 20.05.2020 15:44
They occur on both wireless and ethernet connection. The specifications of the devices I have says it is capable of 1000 Mbit/s but I was never able to get over 700 during the day.
In the evening, it's even slower than during the day.
I have multiple devices with different operating systems. None of them are able to get to the 1000 Mbit/s speed and I'm not sure it's the device to be blamed. I disconnected every device from the router and had only the connected device to test.
am 25.05.2020 12:58
Hi adnedelcu,
I can send another tech to take a look at that connection. Maybe he can find out about the low speed at your place.
Would that be all right with you?
Best Regards, Manu
am 26.05.2020 13:12
Yes, that would be great.
In the past week, the connection was steady, but it is a matter of time until it will go bad again.
am 29.05.2020 08:59
Hi adnedelcu,
well, if it's all right now, there's no need to send the engineer. Then he can't find anything.
What are you getting now?
Best Regards, Manu
am 29.05.2020 10:37
I get around 500 on average, even though speedtest.vodafone.de says I got 600 (haven't even seen once that number in the test).
am 31.05.2020 14:25
Hello adnedelcu,
please do a speed test and send me a screenshot of it. Please measure the speed via LAN.
Best regards
Moni
