22.08.2019 13:03 - bearbeitet 22.08.2019 13:05
Last week, I spent 2h trying to contact vodafone to solve my internet issues.
After hours of fighting on the menu (because I do not speak German), the operator said they are not allowed to speak in English.
I was calling 0800 52 666 25.
I have 200mbps plan, but only 90mbps (after doing speed test)
I am using my computer directly on the vodafone router (the simple version of it), so tried to reset the router.
How can I proceed? Is anyone available to speak on my mobile number and speak in english?
Maybe something is wrong on my building, or I could ask to reset the signal. I do not know ... This is my second time here.
Please, help, otherwise I want to find another provider 😞
am 29.08.2019 15:18
Any chance to have an appointment after 18:30? (And also after 04/september)
(I am tavelling until there)
Thanks again for helping! I Checked again yesterday, tried to remove the cable and put it again, looks the same 80mbps. Can you check if the noise is still bad?
am 29.08.2019 19:46
Hello radicalrj,
yes, i checked the cable-router again and he is online with a normal signal. I see also, that you use the bride-mode with it. But the connection use only 100mbps and nothing more.
That's why you only have a download rate up to 80mbps.
Try a real gigabit ethernet connection to the cable-router. 🙂
Regards
Jens
am 29.08.2019 21:04
I changed the ethernet cable, and looks like the problem is gone! Very strange.
am 02.09.2019 07:39
Hi radicalrj,
I know this issue from myself. The plug was brocken and it seems like, that there were not all cables connected in it. So there was also only 100MBit/s transmitted.
Great that it works with another ethernet-cable
Can I close the thread?
Kind regards
am 02.09.2019 16:55
yes you can! Thanks for helping!
