wifi 2.4 Ghz doesnt connect
chrdi
Hello everyone,
I need to split my wifi to 2.4 and 5 because I cant connect my Smart Bulbs to the mixed one. I did that through the router settings, it looks that both channels are set but I cant connect to the 2.4 one. It says that the password is not correct (which is not the case). The 5 one works normally.
Could anyone help?
Thanks
Moni_GK
Hello chrdi,
Have you assigned a password to the WLAN?
Please perform a factory reset again?
Greetings Moni
