am 23.11.2021 23:18
Hello Team,
My wifi on the Vodafone station router is disconnecting frequently and is highly unstable. Please can you check and if possible upgrade my Vodafone station to wifi 6.
Thank you
Jagkaran Singh
am 29.11.2021 10:22
Hello JagkaranSingh,
I'm sorry you're having dropouts on your connection. You can't swap your device for the Wifi 6 router. Please tell me if you are connected via LAN or WLAN? When do the interruptions always occur?
Best regards
Nancy
am 06.12.2021 08:50
Hello @Nancy
I'm connected to WiFI/WLAN and the interruptions happen throughout the day and the WiFi disconnects after every 15 mins. I am facing disconnection for 1 to 2 months, I also raised the fault ticket which was resolved, and last week I had my router replaced but the replaced router is also causing the same issue.
Please get my issue fixed as I am working from home and facing heavy disconnection issues for a long time.
BR
Jagkaran Singh
am 08.12.2021 14:59
Hi JagkaranSingh,
the signal seems to be good. I'd like to replace the modem for free, okay?
Kind regards
am 09.12.2021 12:53
Hi @pRo-Marco
Yes please, I think replacing the modem with the latest configuration would resolve the issue as I was facing the disconnection issue for a long time.
Do you think this can be fixed by tomorrow (10.12.2021)? As I will be out of town after that.
Best Regards
Jagkaran Singh
am 15.12.2021 19:07
unfortunately it takes several days until we can reply again :/. Please get back in touch with us when you are back home.
Kind regards
am 27.02.2022 19:43
Hello @Claudia
I am back from my long vacation, could you please take this topic on priority as my wifi still keeps on disconnecting. I guess the Vodafone wifi station device has some issues.
Thanks
Jagkaran Singh
am 27.02.2022 19:44
Hello @Claudia
I am back from my long vacation, Could you please take this topic on priority as my Wifi still keeps on disconnecting frequently. I guess the Vodafone wifi station router has some issues.
Thanks
Jagkaran Singh
am 28.02.2022 15:03
Hi JagkaranSingh,
welcome back Please keep the modem connected. At the moment I can't see any problems with the connection.
Kind regards
am 02.03.2022 11:41
Hi @pRo-Marco
Please read the whole thread, it's not the problem with the connection but with the Wifi Router which is disconnecting frequently and hence disrupting the work from home.
As promised in the thread above, could you please replace the router at the earliest?
Thanks
Jagkaran Singh
