am 31.10.2021 21:06
am 03.11.2021 15:31
Hi AidinAzimi,
welcome to our community. Can you please do a factory reset with the router and see if the error messages still show up?
Regards
Wallace
am 03.11.2021 17:52
Hi Wallac,
Thanks for the reply.
Yes i did perform reset and factory reset multiple times but no changes.
I even change the wifi configuration multiple times but no luck.
I have this issue for few month and its getting worth. First it was reset every day and now it is sometimes every minute and if i am lucky i have one hour wifi connection.
Best,
Aidin Azimi
am 08.11.2021 08:35
Hello AidinAzimi,
do you have a contract with Vodafone Kabel Deutschland? If yes, please send me a PM that contains your data (customer number, name and birth date of the contract owner and full address). Leave a short reply here in this thread after you sent the PM.
Kind regards,
am 10.11.2021 00:55
I wrote you a pm with my info.
Thanks
am 15.11.2021 11:49
Hello AidinAzimi,
Are the interruptions via 2. 4 GHz or 5 GHz or both? Does the switch between the two frequencies cause the interruptions? Have you tried to adjust the frequencies? According to history, the last reboot was a week ago. Is that correct?
Best regardsFred
am 15.11.2021 13:03
Hi Fred,
Yes i tried to fix the frequencies and i used multiple wifi freq mappers to find the best one as well.
Both 2.4 and 5 Ghz have the same problem.
I just gave up on the configs so last restart would be correct, i did tried to solve this with customer aupport for months now.
Some how it seems that the wifi module in the device get restarted because the lan connection works fine when wifi gets restarted. So my guess would be some hardware or software issue on the device.
Thanks,
Aidin
am 19.11.2021 12:38
Hello AidinAzimi,
we have tried an update on the modem. Can you please restore the delivery state and test the box again. If this does not work, we will send you an exchange device.
Best regards Fred
am 19.11.2021 18:34
Hello Fred,
Thank you. I did restart the wifi settings and will see how it works. I will update this thread in few days regarding the status of the wifi connection. Hopefully it works.
Beat,
Aidin Azimi
am 21.11.2021 21:04
Hello Fred,
After two days the problem still exist and wifi gets restarted every hour.
Please let me know if i can have a replaced device.
Best,
Aidin Azimi
