am 18.08.2021 13:36
I have a Cable internet and it has a great speed but I have some problems:
1- It disconnected during video / voice calls (it seems upload works fine but download has some issue during the voice call, since they can see or hear me but I lost their voice and video). I should mention the wifi does or internet light stays on on my modem even when chat is disconnected.
2- I can not use my PPTP work office VPN and it seems something related to IPv4 / v6, how can I change my IP to version IPv4?
am 19.08.2021 14:03
Hello HamidAlizadeh,
first of all welcome to our community. Nice that you are here.
Have you ever tested it over a LAN connection? Do the calls take place during a VPN connection?
About IPv4: Have you ever asked your employer if they can also provide an Ipv6 connection?
Before I can help you further, please tell me in which state you live.
Best regards
Tina
am 20.08.2021 12:43
The whatsApp calls are not during the VPN use, I use my iPhone my tablet and an Android phone and all of them have the same issue when using these kind of applications (the over all speed is good I have near 900Mbps/50Mbps to my router and from the wifi I get 120Mbps/50Mbps).
About the IPv6, I ask them but it seems they can not do it in near future.
I live in Kaiserslautern City in Rhineland-Palatinate
am 23.08.2021 14:26
please send me the name of the contract holder, the date of birth, the complete address and the customer number via PN .
After that, please leave a short feedback here.
Many greetings, Martin
am 24.08.2021 15:30
unfortunately you have forgotten the customer number, can you please send it via PN ?
am 25.08.2021 16:20
the connection looks completely inconspicuous. Have you ever reset the cable router to the factory settings?
Are you experiencing any other problems?
Best regards, Martin
am 27.08.2021 01:05
Hello @Martin59 ,
Actually I did not reset factory the modem untill yesterday that you mentioned it using the small button and needle but it still get disconnected in Instagram live or WhatsApp calls.
I also not able to use PPTP vpn connection due to IPv6 assigned to my router that would be better if I had IPv4
Best regards, Hamid
am 27.08.2021 15:21
Hello Hamid,
I have just made an adjustment. Please have a look if it works now.
am 30.08.2021 01:56
It seems the Skype is workinf fine now but I still can not connect to (PPtP) VPN
am 31.08.2021 07:26
your router has DualStack, so it uses IPv6 and IPv4 in parallel. That means from our side everything is enabled for VPN. Please ask the one that provides the VPN for advice and support.
Kind regards
