am 13.04.2022 14:53
Currently, I'm using Vodafone CableMax 1000 and except within the time period 21:00 - 23:30, everything is super fine.
During the day according to Vodafone Speed test:
Download: 942 Mbit/s
Upload: 55 Mbit/s
Ping: 20ms
And according to speedtest.net
Download: 750 Mbit/s
Upload: 55 Mbit/s
Ping: 8ms
I usually play games, except from 21:00 - 23:30, everything is also fine there as I have ping values like 20-30ms, but when the prime time comes (21:00 - 23:30), my connection became an unbearable one.
During this period my ping is around 100-140ms while playing games and my internet speed drops to 50-100 Mbit/s. This is totally unbearable and I literally cannot play any games, and even Youtube/Netflix is freezing while streaming at this period.
Previously (like a year ago), I was using Vodafone Cable 50 and everything was consistent with it, there were no spikes or internet speed changes.
Please let me know, which details are required to investigate this issue further and fix it, otherwise, I'm seriously thinking about changing the provider if I won't be able to use my connection properly all day long and pay a huge amount.
Thanks in advance.
am 14.04.2022 17:04
Hello earth35,
I am very sorry that you are having problems with the speed of the connection.
Can you please write in which federal state you live?
Your measurements are all carried out via LAN directly at our router?
Many greetings Jana
am 15.04.2022 12:06
Hi Jana,
All measurements were done with LAN cable and with the same setup.
I live in Berlin and the postal code of my area is 10178.
Thanks.
am 18.04.2022 11:17
Hello earth35,
I'll take a closer look.
Please send me a PN with the name of the contract holder, date of birth, full address and customer number.
After that, please leave a short info here.
Best regards, Martin
am 19.04.2022 14:01
Hi Martin,
I sent you a PM with all details. Thanks in advance!
Best,
Erdem
am 20.04.2022 10:47
Here is a screenshot that shows the difference between yesterdays evening and this morning 😞
am 20.04.2022 16:44
Hello erde35,
the problems in the evening are caused by a high net utilisation. The colleagues are already working on lowering that utilisation. I made a fault report for you and added it to the central task, so you will get an email when it is closed. According to the current plan that should be done at the end of May.
Kind regards,
am 27.04.2022 22:37
Hi @Claudia,
Thanks for the response. I saw the ticket but it was closed on the same day evening, but my problem is the same nothing has changed.
Could you create another ticket that I can keep an eye on?
Best,
Erdem
am 28.04.2022 13:51
Hello Erdem,
unfortunately there was a system error that closed the last task automatically. That was eliminated now so I opened a new task and added it to the central task again.
Kind regards,
