LITHIUM.Dialog({
"closeImageIconURL" : "https://forum.vodafone.de/skins/images/86BD4BA127551BE2C7C15694C77DEDED/responsive_peak/images/button_dialog_close.svg",
"defaultAriaLabel" : "",
"accessibility" : false,
"dialogKey" : "dialogKey"
LITHIUM.GiveRatingForm('#give-rating-form-message_ratings-3051452 .lia-rating-control-passive', '#form');
LITHIUM.AjaxSupport.fromLink('#kudoEntity', 'kudoEntity', '#ajaxfeedback', 'LITHIUM:ajaxError', {}, 'P22ZXhuepa715eNHdKDs8NR2aGq9XcF6ZOujzwIm0sQ.', 'ajax');
"eventActions" : [
"event" : "kudoEntity",
"actions" : [
"action" : "rerender"
"initiatorBinding" : true,
"parameters" : {
"revokeMode" : "true",
"kudosable" : "true",
"showCountOnly" : "false",
"useCountToKudo" : "false",
"entity" : "3051452",
"linkDisabled" : "false"
;(function($) {
$(document).ready(function(){
})(LITHIUM.jQuery);
"eventActions" : [
"event" : "approveMessage",
"actions" : [
"context" : "",
"context" : "",
"action" : "pulsate"
"event" : "unapproveMessage",
"actions" : [
"context" : "",
"context" : "",
"event" : "deleteMessage",
"actions" : [
"action" : "addClassName"
"context" : "",
"event" : "QuickReply",
"actions" : [
"event" : "expandMessage",
"actions" : [
"event" : "ProductAnswer",
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"selector" : "#messageview",
"parameters" : {
"useSubjectIcons" : "true",
"quiltName" : "ForumMessage",
"truncateBody" : "true",
"message" : "3051452",
"useSimpleView" : "false",
"disableLinks" : "false",
"displaySubject" : "true"
LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"lineardisplaymessageviewwrapper","componentSelector":"#lineardisplaymessageviewwrapper","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":3051452,"confimationText":"Du hast andere Nachrichten-Editoren geöffnet, deren Daten verlorengehen könnten. Bist du sicher, dass du fortfahren möchtest?","loaderSelector":"#lineardisplaymessageviewwrapper .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"});
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#lineardisplaymessageviewwrapper","action":"renderInlineEditForm","feedbackSelector":"#lineardisplaymessageviewwrapper","url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.lineardisplay_1.lineardisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/StorungsmeldungenInternetTVTelefon/thread-id/513194/page/2","ajaxErrorEventName":"LITHIUM:ajaxError","token":"7c9Ene1IWiQeLpmFVub0facqYbntFPRCxBdPfSBqKBo."});
function disableInput(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("disabled","1");
function setWarning(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("class","custom_board_pagination_no warning");
document.getElementById("custom_board_pagination_warning_div" + pagerId).setAttribute("class","custom_board_pagination_warning_div warning");
function clearWarning(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("class","custom_board_pagination_no");
document.getElementById("custom_board_pagination_warning_div" + pagerId).setAttribute("class","custom_board_pagination_warning_div");
function doChecks(pagerId, val) {
var o = document.getElementById("custom_board_pagination_warning" + pagerId);
if (isNaN(val) )
o.innerHTML = "Page must be in a numeric format.
setWarning(pagerId);
return false;
if (val.trim() == "")
o.innerHTML = "";
clearWarning(pagerId);
return false;
if ( Number(val) % 1 !== 0 || (String(val).indexOf(".") > 0) )
o.innerHTML = "Page must be an integer number.
return false;
if ( Number(val) < 1 )
o.innerHTML = "Page number must be 1 or greater.
return false;
if ( Number(val) > 2 )
o.innerHTML = "Page number can\'t exceed 2.
return false;
o.innerHTML = "";
return true;
function processPageInputBlur(pagerId, val)
if (doChecks(pagerId, val))
if (2 != val)
disableInput(pagerId);
window.location = "https://forum.vodafone.de/t5/St%C3%B6rungen-im-Kabel-Netz/Permanente-St%C3%B6rungen-und-Ausf%C3%A4lle-im-Kabelnetz-Rheinland-Pfalz/td-p/3046724" + "/page/" + val;
;(function($) {
$(this).next().toggle();
})(LITHIUM.jQuery);
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lightboxRenderComponent","parameters":{"componentParams":"{\n \"surveyType\" : {\n \"value\" : \"communityexperience\",\n \"class\" : \"java.lang.String\"\n },\n \"surveyId\" : {\n \"value\" : \"3\",\n \"class\" : \"java.lang.Integer\"\n },\n \"triggerSelector\" : {\n \"value\" : \"#valueSurveyLauncher\",\n \"class\" : \"lithium.util.css.CssSelector\"\n }\n}","componentId":"valuesurveys.widget.survey-prompt-dialog"},"trackableEvent":false},"tokenId":"ajax","elementSelector":"#valueSurveyLauncher","action":"lightboxRenderComponent","feedbackSelector":false,"url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.liabase.basebody.valuesurveylauncher.valuesurveylauncher:lightboxrendercomponent?t:ac=board-id/StorungsmeldungenInternetTVTelefon/thread-id/513194/page/2","ajaxErrorEventName":"LITHIUM:ajaxError","token":"GuLhDHabuL3Nz6sbtC_QEP7gdBk8E_Y9vHeMlFvzd6k."});
LITHIUM.Dialog.options['1851258941'] = {"contentContext":"valuesurveys.widget.survey-prompt-dialog","dialogOptions":{"minHeight":399,"draggable":false,"maxHeight":800,"resizable":false,"autoOpen":false,"width":610,"minWidth":610,"dialogClass":"lia-content lia-panel-dialog lia-panel-dialog-modal-simple lia-panel-dialog-modal-valuesurvey","position":["center","center"],"modal":true,"maxWidth":610,"ariaLabel":"Feedback for community"},"contentType":"ajax"};
LITHIUM.Dialog({
"triggerEvent" : "click",
LITHIUM.ValueSurveyLauncher({"detectPopUpCSS":".lia-dialog-open","dialogLinkSelector":"#valueSurveyLauncher","launchDelay":274662});
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay?t:ac=board-id/StorungsmeldungenInternetTVTelefon/thread-id/513194/page/2","ajaxErrorEventName":"LITHIUM:ajaxError","token":"FGFeKZyjrG_0iHFOR7EY2lH9QpYUOW1iNn5v71wtOXk."});
LITHIUM.Auth.CHECK_SESSION_TOKEN = 'ZwajFdbMltZpRFl8pLEF40yk6l_qwQPUsjy-46AIIkI.';
LITHIUM.Cache.CustomEvent.set([{"elementId":"link_5","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3051452}},{"elementId":"link_8","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075090}},{"elementId":"link_9","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075516}},{"elementId":"link_10","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075349}},{"elementId":"link_11","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075098}},{"elementId":"link_12","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075059}},{"elementId":"link_14","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075565}},{"elementId":"link_15","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075555}},{"elementId":"link_16","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075549}},{"elementId":"link_17","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075526}},{"elementId":"link_18","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075504}},{"elementId":"link_19","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075500}},{"elementId":"link_21","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075498}},{"elementId":"link_23","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075468}},{"elementId":"link_24","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075433}},{"elementId":"link_25","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075387}}]);
