No wifi on smart TV
Kensuke
Forum-Checker
Forum-Checker
Hello everyone,
I have a problem for wifi router.
Now the wifi router is available for smartphones without problems.
But when I try to use it for TV for watching Youtube or somthing like that, I cannot see this wifi information on the available wifi list, so cannot select it.
I don't know the route cause and how to fix.
Have you experienced the same situation?
Does anyone know what is happening and how to settle it?
Thank you for your cooperation.
Regards,
Jens
Hello Kensuke,
if you have a connection with your smartphone, the wifi works. Did you have configured your wifi, that is incognito?
Regards
Jens
