Multimedia dosenaufsatz does not fit in my outlet - no internet access
Carnio
I have bought Vodafone cable 1000M and unfortunately I was not able to properly install the router at my home. The house's outlet does not fit with the provided multimedia dosenaufsatz.
I tried to follow the robot debug instructions but it did not work.
I also tried to buy antenna cables to make the connection fit as you can see in the picture but I was not successful.
Could you please provide technical support here?
I have no internet connection for 8 days now and I only wish to make it work.
Unfortunately there is no hotline for English speakers so I could not talk to anyone.
Thanks
9 Antworten 9
Hello Carnio,
please send a picture of the antenna socket where the outlets are visible. Did you check if there are any other antenna sockets in your flat and have you tried to connect the router there? In which federal state do you live?
Kind regards,
Hi Claudia,
thanks for your message.
I have 2 other identical outlets (3 in total) . They all have the same configuration as you can see in the picture.
I tried to connect to all of them and nothing worked.
The Multimedia dosenaufsetz provided by you is to big.
I just wish to have a technical support on the installation of my router.
Could you help me with that, please?
I live in Munch - Bavaria.
Thanks
Hi Claudia,
Thanks
Hi @Carnio,
I can gladly take a look at the connection. Can you send me your customer data (customer number, name, address and date of birth of the contract holder) via private message?
Then please let me know in the post when you have sent me the data.
Regards
Hi Tobias,
I have just answered you in the private channel.
Hope to hear from you soon.
@Tobias I have just answered
Hey @Carnio,
ill need a mobilenumber where the colleagues can reach you, i have to send you a technician 😉 Please via private message. Take care, PM's can only be sended until tomorrow - after that you have to contact us via twitter/facebook.
Regards
Hi @Tobias ,
I have just sent you my contact where you can reach me out
There is my phone number and also my email address.
I hope to hear back from you soon.
Regards
Hi @Carnio,
my colleagues cant contact that number. Did you got a mobile number or a number located here in Germany? 🙂
Regards
