LITHIUM.Dialog({
"closeImageIconURL" : "https://forum.vodafone.de/skins/images/D8EC074C2B7D58897410E9BBB9FB4949/responsive_peak/images/button_dialog_close.svg",
"defaultAriaLabel" : "",
"accessibility" : false,
"dialogKey" : "dialogKey"
LITHIUM.GiveRatingForm('#give-rating-form-message_ratings-2734454 .lia-rating-control-passive', '#form');
LITHIUM.AjaxSupport.fromLink('#kudoEntity', 'kudoEntity', '#ajaxfeedback', 'LITHIUM:ajaxError', {}, 'x8yfi0tD76O9jE-xoB4d_DfqXNylnmyEeB7fpzVVHTM.', 'ajax');
"eventActions" : [
"event" : "kudoEntity",
"actions" : [
"action" : "rerender"
"initiatorBinding" : true,
"parameters" : {
"revokeMode" : "true",
"kudosable" : "true",
"showCountOnly" : "false",
"useCountToKudo" : "false",
"entity" : "2734454",
"linkDisabled" : "false"
;(function($) {
$(document).ready(function(){
})(LITHIUM.jQuery);
"eventActions" : [
"event" : "approveMessage",
"actions" : [
"context" : "",
"context" : "",
"action" : "pulsate"
"event" : "unapproveMessage",
"actions" : [
"context" : "",
"context" : "",
"event" : "deleteMessage",
"actions" : [
"action" : "addClassName"
"context" : "",
"event" : "QuickReply",
"actions" : [
"event" : "expandMessage",
"actions" : [
"event" : "ProductAnswer",
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"context" : "",
"actions" : [
"actions" : [
"actions" : [
"actions" : [
"selector" : "#messageview",
"parameters" : {
"useSubjectIcons" : "true",
"quiltName" : "ForumMessage",
"truncateBody" : "true",
"message" : "2734454",
"useSimpleView" : "false",
"disableLinks" : "false",
"messageViewOptions" : "1111110111111111111110111110100101011101",
"displaySubject" : "true"
LITHIUM.MessageViewDisplay({"openEditsSelector":".lia-inline-message-edit","renderInlineFormEvent":"LITHIUM:renderInlineEditForm","componentId":"lineardisplaymessageviewwrapper","componentSelector":"#lineardisplaymessageviewwrapper","editEvent":"LITHIUM:editMessageViaAjax","collapseEvent":"LITHIUM:collapseInlineMessageEditor","messageId":2734454,"confimationText":"Du hast andere Nachrichten-Editoren geöffnet, deren Daten verlorengehen könnten. Bist du sicher, dass du fortfahren möchtest?","loaderSelector":"#lineardisplaymessageviewwrapper .lia-message-body-loader .lia-loader","expandedRepliesSelector":".lia-inline-message-reply-form-expanded"});
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:renderInlineEditForm"},"tokenId":"ajax","elementSelector":"#lineardisplaymessageviewwrapper","action":"renderInlineEditForm","feedbackSelector":"#lineardisplaymessageviewwrapper","url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.lineardisplay_1.lineardisplaymessageviewwrapper:renderinlineeditform?t:ac=board-id/StorungsmeldungenInternetTVTelefon/message-id/424681","ajaxErrorEventName":"LITHIUM:ajaxError","token":"qV72_grGh37MUtYkEVuUw-AoCcdWlUDjRzQxz6gU9sc."});
function disableInput(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("disabled","1");
function setWarning(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("class","custom_board_pagination_no warning");
document.getElementById("custom_board_pagination_warning_div" + pagerId).setAttribute("class","custom_board_pagination_warning_div warning");
function clearWarning(pagerId) {
document.getElementById("custom_board_pagination_no" + pagerId).setAttribute("class","custom_board_pagination_no");
document.getElementById("custom_board_pagination_warning_div" + pagerId).setAttribute("class","custom_board_pagination_warning_div");
function doChecks(pagerId, val) {
var o = document.getElementById("custom_board_pagination_warning" + pagerId);
if (isNaN(val) )
o.innerHTML = "Page must be in a numeric format.
setWarning(pagerId);
return false;
if (val.trim() == "")
o.innerHTML = "";
clearWarning(pagerId);
return false;
if ( Number(val) % 1 !== 0 || (String(val).indexOf(".") > 0) )
o.innerHTML = "Page must be an integer number.
return false;
if ( Number(val) < 1 )
o.innerHTML = "Page number must be 1 or greater.
return false;
if ( Number(val) > 2 )
o.innerHTML = "Page number can\'t exceed 2.
return false;
o.innerHTML = "";
return true;
function processPageInputBlur(pagerId, val)
if (doChecks(pagerId, val))
if (1 != val)
disableInput(pagerId);
window.location = "https://forum.vodafone.de/t5/St%C3%B6rungen-im-Kabel-Netz/Kindle-kann-keine-WLAN-Verbindung-zum-Router-CG4233DE-herstellen/td-p/2726745" + "/page/" + val;
;(function($) {
$(this).next().toggle();
})(LITHIUM.jQuery);
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:lightboxRenderComponent","parameters":{"componentParams":"{\n \"surveyType\" : {\n \"value\" : \"communityexperience\",\n \"class\" : \"java.lang.String\"\n },\n \"surveyId\" : {\n \"value\" : \"3\",\n \"class\" : \"java.lang.Integer\"\n },\n \"triggerSelector\" : {\n \"value\" : \"#valueSurveyLauncher\",\n \"class\" : \"lithium.util.css.CssSelector\"\n }\n}","componentId":"valuesurveys.widget.survey-prompt-dialog"},"trackableEvent":false},"tokenId":"ajax","elementSelector":"#valueSurveyLauncher","action":"lightboxRenderComponent","feedbackSelector":false,"url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.liabase.basebody.valuesurveylauncher.valuesurveylauncher:lightboxrendercomponent?t:ac=board-id/StorungsmeldungenInternetTVTelefon/message-id/424681","ajaxErrorEventName":"LITHIUM:ajaxError","token":"4KyyBajUtBu7bgZ-UfL_vZmgDpU2sTKQHs3e8d9UpzI."});
LITHIUM.Dialog.options['1468807225'] = {"contentContext":"valuesurveys.widget.survey-prompt-dialog","dialogOptions":{"minHeight":399,"draggable":false,"maxHeight":800,"resizable":false,"autoOpen":false,"width":610,"minWidth":610,"dialogClass":"lia-content lia-panel-dialog lia-panel-dialog-modal-simple lia-panel-dialog-modal-valuesurvey","position":["center","center"],"modal":true,"maxWidth":610,"ariaLabel":"Feedback for community"},"contentType":"ajax"};
LITHIUM.Dialog({
"triggerEvent" : "click",
LITHIUM.ValueSurveyLauncher({"detectPopUpCSS":".lia-dialog-open","dialogLinkSelector":"#valueSurveyLauncher","launchDelay":274521});
LITHIUM.AjaxSupport({"ajaxOptionsParam":{"event":"LITHIUM:partialRenderProxyRelay","parameters":{"javascript.ignore_combine_and_minify":"true"}},"tokenId":"ajax","elementSelector":document,"action":"partialRenderProxyRelay","feedbackSelector":false,"url":"https://forum.vodafone.de/t5/forums/v4/forumtopicpage.liabase.basebody.partialrenderproxy:partialrenderproxyrelay?t:ac=board-id/StorungsmeldungenInternetTVTelefon/message-id/424681","ajaxErrorEventName":"LITHIUM:ajaxError","token":"MLyfrCsln3VcbRx9WJi_kQHVctKZGe7SnWv4ZZ-Ic9Y."});
LITHIUM.Auth.CHECK_SESSION_TOKEN = 'uQl4T7zT4wmZ9XBK_YFN4_dCMcwblmLhuwzoN8Q88_Q.';
LITHIUM.Cache.CustomEvent.set([{"elementId":"link_6","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":2734454}},{"elementId":"link_9","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075090}},{"elementId":"link_10","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076155}},{"elementId":"link_11","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076109}},{"elementId":"link_12","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076003}},{"elementId":"link_13","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3075808}},{"elementId":"link_15","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076288}},{"elementId":"link_16","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076211}},{"elementId":"link_17","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076204}},{"elementId":"link_18","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076147}},{"elementId":"link_19","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076073}},{"elementId":"link_20","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076058}},{"elementId":"link_21","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076035}},{"elementId":"link_22","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076014}},{"elementId":"link_23","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076013}},{"elementId":"link_24","stopTriggerEvent":false,"fireEvent":"LITHIUM:selectMessage","triggerEvent":"click","eventContext":{"message":3076010}}]);
