Kabel issues (English)
Raphaelom
Sorry for posting in English.
I have a lot of instability with my cable connections, some sites are blocked and some respond only once in a while. They work correctly when using a VPN so I suspect it`s either a filtering from vodafone or a route misconfigured/overloaded. Since I see no way to removing all filtering here is my list of problems:
id.atlassian.com
https://kabel.vodafone.de/
eu.api.blizzard.com
eu.patch.battle.net
I also have a traceroute avaibale attached. I have tried all the steps in the manual, connecting directly using ethernet cable, reseting the router, etc
Hello Raphaelom,
the traceroute shows that the request leaves our net without any problem and with a good latency. I can see no error there.
Kind regards,
