am 02.08.2022 23:23 - zuletzt bearbeitet am 03.08.2022 07:35 von Anett
Hello,
I connected my Vodafone Wi-Fi 6 Station properly but the internet led has been blinking red light for one day. The type of designation is TG6442VF which is written on the back of the station. I also tried to check the settings of the router by entering the http://192.168.0.1. But the status of DOCSIS Offline. I also attached DOCSIS Status and Downstream channel(s). It is obvious that something is wrong because modulation is not supported but I don't know what the matter is.
I'm trying to connect the router via WiFi. Please help me, what should I do?
Thank you in advance.
@mustafat Post moved to the appropriate board.
am 03.08.2022 07:01
call the support or wait here 4 some help
please choose now
am 04.08.2022 12:02
Hi @mustafat,
I can gladly take a look at the connection. Can you send me your customer data (customer number, name, address and date of birth of the contract holder) via private message?
Then please let me know in the post when you have sent me the data.
Regards
am 04.08.2022 13:31
Hier bei mir gibt es seit dem ersten Anschluß der Vodafone Station (WiFi 6) kein Netz. Blinkt auch rot. Anlage im Keller erst 2 Jahre alt. Techniker kommt erst in einer Woche. Sollte doch mit der Selbstinstallation funktionieren. Bei Vodafone kann angeblich niemand was machen. Warum sagt dass eine Selbstinstallation ausreicht wenn hier doch kein Signal an der Anlage anliegt?
