easybox 805 activation fails
sreejithvijayan
My easybox was iinstalled yesterday by technician. I activated using MIC but since yesterday, it is stuck at 'Activation in progress. Please help.
Andre
Ex-Moderator:in
Ex-Moderator:in
Hey sreejithviiayan,
did you connect the router according to the manual with the telephone connection socket?
Then my colleagues from the technical department neeed to have a closer look.
Therefore please send me a private message with your dsl customer / mobilenumber.
Click on my name/avatar -> then the big red button on the right side.
Cheers,
Andre
