New DSL Connection Problem, Previous Resident Used a Different ISP
LukeEarthwalker
Hello everyone, sorry my German is very limited so I will have to explain the issue in English.
I have been having problems with the onboarding of my DSL connection after I moved into a new address and wonder if anyone has experienced something similar or has some tips to offer.
I was already a happy Vodafone Kabel customer, however I had to give up the cable contract since the building I moved into only has access to DSL. After the move, when the Telekom technician arrived to install the DSL connection on behalf of Vodafone, he discovered that there was no signal going from my apartment to the central connection box in the garage/cellar. To explain the setup as best as I can, there is a small box in the apartment which houses the connection to the garage as well as the connection to each socket inside the apartment. The technician could find a signal from the modem to this small box, but no signal from this small box to the garage. He then explained to me that he set everything up for my connection to become online as soon as the issue with the wiring between the apartment and the garage is fixed, and that he talked to the Hausmeister and told him to call an electrician to investigate since the ISP is not responsible for the wiring of the building.
Unfortunately, when I asked the Hausmeister for an update the next day, he told me that he does not think there is a problem with the wiring since no one else in the building has any issues and that other residents have recently had their DSL connections installed without any issue. He believes the technician may have overlooked something and recommended that I contact Vodafone again and ask them to take another look.
I talked to the previous resident of the apartment and he told me that he was able to connect to the internet without issue, however he was using a different provider. I then asked the Hausmeister if there was a separate connection box for the other ISP and he said yes. However, when I asked him follow-up questions about whether or not the apartment could still be connected to the wrong box, he said he did not know. Granted, there is a bit of a language barrier between the Hausmeister and I so it is possible that I may have misunderstood what he said.
Now, I am beginning to suspect that the apartment is in fact connected to the wrong ISP box. I have done some Googling and from what I've gathered such cases can indeed happen. The fact that the building is relatively new and the previous resident did not have any issues makes me think that the wiring is probably fine. I have already opened a ticket with Vodafone to investigate the issue, however it has not changed its status in days and I suspect it will be weeks before someone can come over and look. Since I work from home and the mobile reception in my area is quite poor, I am in dire need of a quick solution.
Has anyone experienced something similar? Any help would be much appreciated, thank you.
R4mona
Good morning @LukeEarthwalker,
Thank you so much for taking the time to explain your situation so clearly — I can absolutely understand how frustrating and stressful this must be, especially when you're working from home and relying on a stable connection. 😞
From what you’ve described, it sounds like you’ve done everything right: you followed the technician’s instructions, spoke with the building manager, reached out to us, and even investigated the previous tenant’s setup. The fact that the technician suspects a wiring issue between your apartment and the central box, while the Hausmeister believes everything is fine, puts you in a difficult position — especially with the added language barrier. It’s very possible, as you suspect, that your apartment is still connected to a different ISP’s distribution point. This can happen, especially in newer buildings with multiple providers and separate infrastructure. Since the previous tenant used a different provider, the internal wiring might still be routed through their box.
Here are a few steps you can take now:
Follow up on your ticket: If the status hasn’t changed in days, I recommend contacting Vodafone again — ideally via their https://vod.af/whatsapp for a quicker and more direct response. Mention the technician’s findings and your suspicion about the wrong ISP box.
Ask for a second technician visit: Given the conflicting information, a second on-site check might help clarify whether the apartment is wired correctly for Vodafone DSL or if a switch is needed.
Document everything: Keep a record of your communication with Vodafone, the technician, and the Hausmeister. This can help escalate the issue if needed.
Temporary alternatives: If mobile reception is poor, you might ask Vodafone if they can offer a temporary solution like a GigaCube or data volume boost until the DSL issue is resolved.
You’ve clearly been very patient and proactive — I really hope we can now meet you halfway and get this sorted quickly.
Kind regards
R4mona
Hello R4mona,
Thank you for your detailed response and your very kind words.
On Tuesday I received a phone call from a member of Vodafone's technical team who insisted that I needed new wiring from my apartment to the garage because Willy.tel and Vodafone/Telekom use different technologies. After I insisted that I suspected it was a simple case of a cable somewhere going into the wrong distribution box, he asked me to contact Willy.tel.
Willy.tel immediately told me that it was not my responsibility to contact them as an end user and it is up to Vodafone to coordinate the ISP switch with them. Based on the information they have provided me, it appears that they do not believe that the installation of a new line is needed either.
Since then I have had some WhatsApp chats with the support team, however they believe the technician's findings to be correct and request that I speak to the property management. This is a relatively new, modern building and was designed to provide internet access to every apartment along with other utilities like water and electricity. I do not believe there is any reason to retrofit the building just for one apartment to connect to a different ISP. There are customers of Vodafone, Telekom & Willy.tel in the building who are using the exact same infrastructure as I do. Since the technician's advice on the phone has already proven to be unreliable, I am inclined to believe that the issue lies elsewhere and a new line is not needed.
As you have suggested, I feel the best way to move forward is with another on-site visit to clarify with both the property management and Vodafone/Telekom what needs to be done. However, since I have not been able to achieve that result via the support team, do you have any advice on how to escalate this issue?
Thank you and kind regards.
Hello @LukeEarthwalker ,
the support team should be able to escalate this so far. Please contact them directly. That would be the only way.
Best regards Ufo36
