am 14.08.2020 11:48 - zuletzt bearbeitet am 14.08.2020 11:51 von pRo-Marco
Hi, router shows 4 of the 5 lights on, middle one is off. Normally wifi worked with these settings.
But not able to connect now to wifi. Customer number is XXX
EDIT @Shadab Please don't post personal data. Kind regards Marco
am 14.08.2020 15:53
You can also perform the reset using the button on the back. You have to press and hold it for at least 10 seconds.
Regards
Wallace
am 14.08.2020 11:54
Thanks Marco, Is there an english helpline number I can call?
am 14.08.2020 14:30
I am trying to reset router password. On logging into 192.168.0.1, it asks for password for admin user. I try to give password mentioned on back of router but those are not working.
Where can I get the password?
am 14.08.2020 15:53
Regards
Wallace
am 14.08.2020 17:27
Thanks that worked. Please close the thread.
am 14.08.2020 17:57
Hi Shadab,
thank you very much for your feedback. This concludes my contribution.
If you have further questions or concerns, please feel free to create a new post.
Best regards, Martin
