am 25.06.2019 14:53
Hello there,
I have been using DSL connection with Vodafone, for the past few weeks I am experiencing very slow connection.
Since i don't speak Deutsch, there is no opportunity to explain the issue to customer care. Can someone help me with this?
Thank you
am 26.06.2019 10:21
Hi SD1,
i'm sorry for the issue.
Did you reboot the router? Can you please do 3 speed checks via speedcheck.vodafone.de at different times? At least 6 hours between measurements would be great. Note the IDs please.
After the measurements send me a private message with the following informations, please.
->Customer oder landline number
-> Your (german) mobile number
-> 3 Speedcheck IDs
I'll check your landline and will be back to you asap.
Best regards,
Norman
