Not used my CallYa SIM card for a long time and now it's not working
Gelöschter User
Nicht anwendbar
Hello,
I have not used my CallYa SIM card for a long time and now it's not working, the CallYa SIM is not detected. I am even unable to login to the app to order a new one. Could someone please help to activate the sim or fix this issue.
@Gelöschter User: moved to correct board. BR Chr1ssy
Chr1ssy
Hi @Gelöschter User,
it seems that we deactivated your card. That happens if the card is not used in a long time.
To check if we could reactivate your card, pls get again in contact with us via the following possibilities
best regards
Chr1ssy
Chr1ssy
best regards
Chr1ssy
