am 21.05.2018 22:53
I recently moved to Germany and this is my first time getting cable internet. It's horrifyingly slow during nights. I basically CAN NOT STREAM 16 0p !!! This is ridiculously slow!
1 person speaking English, she has said that there's going to be an installation on the way. Speed has not gotten better whatsoever, some nights are even worse than others. I am very disappointed with the service.
am 01.06.2018 21:44
HI darvishzadeh,
Part of the work has already been completed, so the bandwidth in the evening should no longer fall sharply.
Regards
Wallace
am 24.05.2018 17:01
Hello darvishzadeh,
can you tell me, what cablerouter you use? And it's all day long?
Did you use also a wifi or ethernet connection?
Regards
Jens
am 29.05.2018 11:28
It looks like to be Sagemcom FAST5460. taken from https://kabel.vodafone.de/hilfe_und_service/geraete/wlan_kabelrouter
All day? No. Streaming live video becomes high quality almost the rest of the day, occasional bumps, the main issue is only around 21:00 to 00:00 (3 hours).
I tend to use 5GHz wifi connection. My laptop and mobile phone don't have ethernet port. I can't cable my entire house for everyone to use internet.
Also another issue with modem: I have tried separating USSID of 2.4GHz and 5GHz, but the 5GHz sometimes goes off completely and I have to reset the modem to get it back. Resetting modem takes a long time and this process is obnoxious.
I'll take DSL if it provides a stable connection.
am 30.05.2018 08:59
Hello darvishzadeh,
thanks for your detailed answer.
Let me know your personal data (customer number and name) in a pm. Then I can control time in the evening.
If you use the 5GHz wifi, what distance did you have to the cablerouter? Sometimes it's better to use a repeater.
Regards
Jens
am 31.05.2018 13:53
Hello darvishzadeh,
thanks for your pm.
I can see, that the bandwidth is low in the evening and i create a ticket for you.
The colleagues work on that and hope to finish it until July.
Regards
Jens
am 31.05.2018 14:00
Okay, thanks. Although that sounds quite familiar 😅
I was told the same last month in April that it'll get resolved by middle of May.
Now we wait for July. July comes, I will be told that it'll get fixed by September.
Vicious cycle. Where do you think customer dissatisfaction comes from? 😕
am 01.06.2018 21:44
HI darvishzadeh,
Regards
Wallace
am 04.06.2018 23:19
Hey Wallace and Jens,
True; I had to track it for few days, seems a lot better.
Thanks for your responses.
Sonny
am 07.06.2018 19:44
Hello Sonny,
sounds good :). Is it okay if I close your thread then?
Kind regards
am 08.06.2018 11:18
Sure feel free to do so!
Cheers
Sonny
