Behoben Kempten: Ausfall TV und Radio über Kabel
am 12.02.2019 21:12
am 15.02.2019 09:51
Hello fotoramic,
the contact form is the right way, because in MeinVodafone a contract cancellation is not possible. You can only cancel options.
Rergards
Grit
13.02.2019 08:48 - bearbeitet 13.02.2019 08:49
Hi @fotoramic,
You can also terminate your contract about your profile on "MeinVodafone Portal" or via contact form.
https://www.vodafone.de/contact/rf/contactform.jsp
am 14.02.2019 13:39
am 15.02.2019 09:51
Hello fotoramic,
Rergards
Grit
am 17.02.2019 18:26
am 18.02.2019 21:26
am 19.02.2019 16:46
Hi fotoramic,
the cancellation has been processed. You will also receive a confirmation.
Regards
Thomas
