am 26.10.2020 20:42 - zuletzt bearbeitet am 26.10.2020 21:05 von Grit
I want to Downgrage my Kable Internet from 1000Mbps to 50Mbps
can someone help for this?
My couster number : ***
Thank you
Edit: Customer number removed for data protection reasons. VF_Grit
am 28.10.2020 11:28
Hello Pooja,
thanks for your PN and your data. 🙂
A change to Internet & Phone 50 is possible on 24.03.2021. If you like, I will make everything ready.
Regards
Anett
am 27.10.2020 09:09
Hello Pooja,
welcome to the community. 🙂
I will gladly help you with the downgrade. In order for me to do so, I need your data (name, customer number, address and date of birth) via PN.
As soon as this is out, please contact me again here in the post.
Regards
Anett
am 27.10.2020 13:50
Hello Team.
i sent the details in private message,
Kindly check and downgrade my internet tarrif
am 28.10.2020 11:28
Hello Pooja,
Regards
Anett
am 28.10.2020 12:40
Hello Anett,
Thank you for your information.
I'm confirming you : please downgrade to 50Mbps. (from 24.03.2021)
Thanks for your support
Regards,
Pooja
am 28.10.2020 13:47
Hello Pooja,
I finished the change. You will receive a written confirmation in March.
Regards
Anett
am 28.10.2020 15:06
Thank you So much...
this portal helps lot.
am 30.10.2020 10:41
Hello Pooja,
we are happy to read.
Since everything could be cleared with you, I will put a lock on your thread.
Best regards
Nancy
