am 21.09.2021 21:08
I contracted an Internet through Cable connection (100 Mbit) on a Vodaphone booth. I received my router by mail on friday 17/09, the internet connection started on the same day, but the wifi has had stability issues since the beginning (the connection goes out for some seconds/minutes and comes back). This happens in all the devices I have connected to the router. The previous tenant of the apartment had no issues with the internet, as far as I know (also a vodafone client), so I suspect that the router could be the issue.
I am looking forward to your reply, thanks.
Best regards,
Mauricio.
am 22.09.2021 09:08
Hallo , what Type of Router do you use?
and is he sending in 2,4 GHZ and 5 GHZ at the same time with same SSID ?
when this happend give them a separate Name /ID Example 2,4 GHZ One and 5 GHZ Two
and restart rooter
am 22.09.2021 22:50
Hallo Dieterle,
Thank you for the recommendation. Sadly, I separated the 2.4 and 5.0 Ghz signals yesterday, but the instability in the connection persists (took me 10 minutes to send you this message).
Hope someone from vodafone can look at this issue soon.
Regards,
Mauricio.
am 23.09.2021 07:53
Hello Mauricio i am sorry that i clouldn`t help you to success .
Yes its better someone from Vodafone should help you 👍
Regards
Dieter
am 23.09.2021 16:32
Hello Mauricio93,
we will be happy to take a look at it. In which state do you live and does the interference also occur via LAN?
Best regards, Martin
am 23.09.2021 16:44
Hello Martin,
Thanks for your help. I am currently located in NRW (in Aachen).
I haven't checked the conection through LAN, since the router is not located near my desk. I can do it once I arrive home today.
It must be mentioned that the internet goes down on all the connected devices at the same time.
Regards, Mauricio.
am 23.09.2021 23:35
Hallo Martin,
I tested the LAN connection today, it is also unstable and the internet connection is lost at the same time that devices connected by Wifi.
am 26.09.2021 21:06
Up! The situation hasn't improved.
am 28.09.2021 09:22
Hallo Martin,
Just a reminder to check this issue please, the connection is too unstable to be useful (drops every 5-10 mins or so).
Thanks,
Mauricio.
am 29.09.2021 11:09
Good morning Mauricio,
I am very sorry that your connection is not working properly. It's definitely not supposed to be like this.
Please be so kind and send me a private message with the following data: Customer number, name, address, date of birth, state and current mobile phone number.
Please report back here as soon as the message is out. We will then take care of your concern together and start an error analysis.
Kind regards
R4mona
