am 24.01.2019 10:29
am 24.01.2019 12:58
Hey Rushab,
til someone with more knowledge may help you, here a few tips.
It is possible to transfer your current contract to another person, but not if it's a cable contract.
Important informations about assumption of contract
For your cable contract use the service for relocation:
https://kabel.vodafone.de/meinkabel/meine_kundendaten/umzugsservice
Cheers
am 24.01.2019 16:34
Hi Rushab,
what kind of contract do you have (DSL or cable)?
Regards
Thomas
am 24.01.2019 19:35
am 26.01.2019 07:55
Hi Rushab,
then it is as @freilinger has already described it. You can order the move to the new address for your connection.
Regards
Stephan
am 27.01.2019 03:11
Hey @Rushab,
if you are wondering because you already have a internet connection at your new place, vodafone should realize this. I don't whats happening in this case, though. You might get the same conditions as in your current cable contract or you can cancel it.
Cheers
27.01.2019 03:31 - bearbeitet 27.01.2019 03:31
As the followers said: In some regions/towns u proberly got a calbe connect with ya rent-contract. If so, all will be fine. If not, its possible even. Just listen to the mods here. Help will go on.
