am 18.03.2019 19:06
Please terminate my Wi-Fi Hotspot Flat (WLAN-Hotspot).
Reason: I never used it.
Thanks in advance,
am 22.03.2019 21:53
Hi TerminateWLAN-H,
okay, we just cancelled the Vielfalt HD at the end of the runtime. You will also get a confirmation.
Regards
Thomas
am 19.03.2019 14:38
Hi TerminateWLAN-H,
send me your customer number, name, date of birth and address in a private message.
Then reply again here in the post.
Regards
Thomas
am 20.03.2019 18:40
Message was sent.
Thanks in advice,
am 20.03.2019 19:23
Thomas,
Additionally to my plan (Red Internet & Phone 100 - 43,98 Euros - Correct!). I have been charged 11,99 Euros. Two questions:
1. What is Vodafone charging me for?
2. Why the 19,99 Euros aren't listed in the invoices?
Thanks in advance,
am 20.03.2019 20:27
Hallo TerminateWLAN-H,
under the customer number i can only find the Internet & Phone bill with 43.98 euros. Do you have another customer number with a TV contract?
Regards
Thomas
am 20.03.2019 21:54
You are right! I found it with a different number. 10.00 Euros: Kabel Digital, Produkt: Smartcard TV Vielfalt HD Kabel.
9,99 Euros: Kabel Digital, Produkt: TV Komfort HD Kabel. It looks to me expensive. Can you explain to me if it's possible to reduce the final value?
Thanks in advance,
am 21.03.2019 15:30
Hi TerminateWLAN-H,
we could cancel Vielflat HD at the end of the term 08.08.2019. Then you save 9,99 Euro per month.
Regards
Thomas
am 22.03.2019 18:05
Yes, please cancel it. What about the other 10.00 Euros? Is it possible to cancel both of them (TV Vielfalt HD Kabel (10,00 Euros) and TV Komfort HD Kabel (9,99 Euros))? We only have one TV, internet and we don't use any fixed phone line.
Thanks in advance,
am 22.03.2019 19:17
Hi TerminateWLAN-H,
it's basically just a TV contract. There is as main component TV comfort. Vielfalt HD is an additional channel package.
Regards
Thomas
am 22.03.2019 19:42
Thank you! Please cancel it and let me know if you need something else.
Regards,
