am 31.07.2019 09:59 - zuletzt bearbeitet am 31.07.2019 10:03 von Thomas
Dear Vodafone!
I am sorry but I don't speak german. I hope that you can help me anyway.
I cancelled my Internet contract a while ago with help from you. Thank you very much for the help!
I received an instruction to return the modem. I was away on work abroad for a while and recently came home. I have now returned the modem but have also receieved a "Manung" to immediately pay €102,50 since the modem was not returned in time.
What happens now? Do I need to pay the €102,50?
Thank you for your help!
best regards, Joel Stenberg
Edit: @Joel_Stenberg post moved in to the right board
am 02.08.2019 09:43
Hello,
no no no, that's not how it works. Please do not send me any data publicly here. I have not requested any yet. I only asked if the device had arrived at Vodafone and had been delivered. Because only then can a deregistration be made. It is clear that it will be charged if it is sent back too late. If you simply send it back although it has already been charged, it will not be refunded without further ado.
Regards
Grit
am 01.08.2019 07:45
Hello Joel,
when did you send the modem back? Have we already received it? I ask, because I can only check it out if an input of the device is visible.
Regards
Grit
am 01.08.2019 12:44 - zuletzt bearbeitet am 02.08.2019 12:16 von Grit
Dear Grit!
Thank you for your reply!
I sent it monday this week. It had a Sendungsnummer: ***.
Thank you for helping me with this issue!
best regards, Joel
am 02.08.2019 09:43
Hello,
Regards
Grit
am 02.08.2019 10:20
Dear Grit!
Thank you for your answer! Perhaps you can help me by deleting my last post then?
Thank you in advance!
//Joel
am 02.08.2019 12:21
This is how we do it:
You'll be back in your post here at the beginning of the week. Additionally, you will send me a private message next week with your name, address, customer number and date of birth. I will then see if the device has been received and deleted from your customer data. If this is the case, I can arrange for a credit note to be issued.
PS: I deleted the number from your last post.
Regards
Grit
am 05.08.2019 11:52
Hello Joel,
the hardware has been received by us. The invoiced amount will be credited to your customer account.
Best regards
Tina
am 05.08.2019 12:58
Many thanks!
