am 23.04.2021 16:44
Hi Vodafone team,
I am currently on 'Internet & Phone 1000 Cable' Tariff plan and I am completing my first year of the contract on 23.04.2021.
As suggested in the beginning of the contract, I request to change my tariff plan to 'Red Internet & Phone 250 Cable'
Look forward to your assistance.
am 27.04.2021 08:30
Hello Gani_,
no problem, your new tariff is now active.
I will therefore close your post.
Best regards
Nancy
am 24.04.2021 08:29
Hello Gani_,
you're a little late. The changeover takes place on the exact day and the second part of the term begins with the changeover. However, this is not possible retroactively. The 250 Mbit/s are listed in the order confirmation? In which federal state do you live?
Regards
Grit
am 24.04.2021 08:51
Hi Grit,
I cannot be more early. I am currently in Dresden, Saxony.
Since I moved from one apartment (Vodafone DSL) to another in April. 2020.
The Vodafone agent in Dresden transferred my contract to Vodafone Kabel with an extended 2-year contract with an offer to 'Internet & Phone 1000 Cable' at 19,99 Euro and asked me to downgrade in May 2021 if at all I want internet connection at the same price.
That's the reason, I am proactively asking to downgrade my Internet plan so that it fit the same price. I am also GigaKombi customer. If you need to check, I can provide the contract and other details in a private message.
am 25.04.2021 15:32
Hi Gani_,
I think there’s been a little misunderstanding with my colleague. We would like to take a closer look.
Please send me a private message with the following information:
your name
your address
date of birth
customer number
e-mail address
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
am 25.04.2021 15:41
Hi Stephan,
I have sent a private message with the details as required.
am 25.04.2021 16:54
Hi Gani_,
thanks for your pm.
I had a look in your contract details. After the first year you can change to Red Internet & Phone 200 Cable to 39,99 Euro per month.
If that's okay for you, please let me know and I'll change the tariff for you.
Regards
Stephan
am 25.04.2021 18:49
Hi Stephan,
Thanks for looking into the details, appreciate it.
I also happen to look at my contract sheet that had additional papers and found out that I also have the possibility to change it to the tariff Red Internet & Phone Cable 100, based on my usage consumption I would think this would suit me better.
Request to update my tariff plan to Red Internet & Phone Cable 100 and look forward to your confirmation after the change. Thank you.
am 25.04.2021 19:55
Hi Gani_,
no problem. I'll change the tariff for you.
The change will be carried out today and you'll get a confirmation in the next few days.
Regards
Stephan
am 25.04.2021 21:12
Appreciate the prompt resolution, Stephan. Cheers!
am 27.04.2021 08:30
Hello Gani_,
Best regards
Nancy
