am 02.12.2018 19:16
Hello,
I have kabel internet 200, but since couple of weeks I noticed the speed is slower a bit. When I tested it using the internet test website I had a maximum of 100 Mbps for the download speed. I tried the test couple of times in different days with the same result.
Can you fix the problem so I can optain my normal internet speed?
Thanks,
am 31.12.2018 19:08
Hello Claudia,
Yes you are right. It was a cable issue. For some reason this cable now only provides 90 Mbps instead of 200. Thanks a lot for your help.
Ahmad
