Downgrade Red Cable1000 to Cable 200
Roza
Hi. I'd like to downgrade my internet plan from 1000 to 200 Cable plan after the first year is elapsed. Contract start is 04/02/2020.
I'd also like to cancel the security package. I just noticed I am being charged for it since June and I didn't order that.
Please let me know which additional information is required.
Thank you in advance.
Rosemary Adejoh
Grit
Ex-Moderator:in
Ex-Moderator:in
Hello Roza,
i have the downgrade to 200 MBit/s to 02.04.2021 noted. The booking will be made on the day of the downgrade and then the confirmation will be sent. So you don't have to do anything else regarding this.
Do you have any further questions?
Regards
Grit
7 Antworten 7
Grit
Ex-Moderator:in
Ex-Moderator:in
Hello Roza,
i'll take a look at it. Send me a private message with your name, full address, customer number and date of birth. Important: Afterwards, please report back here in the thread.
Regards
Grit
Roza
Hi! Details sent.
Grit
Ex-Moderator:in
Ex-Moderator:in
Hello Roza,
Regards
Grit
Roza
Great! Thank you.
And is the security package also cancelled?
Rosemary
Grit
Ex-Moderator:in
Ex-Moderator:in
Hello Roza,
yes, I have stopped the cancellation for the security package. You will get an extra confirmation for this.
Do you need any other information or can we finish the contribution with that?
Regards
Grit
Roza
Hello,
That will be all, thank you.
Tina
Ex-Moderator:in
Ex-Moderator:in
Hello Roza,
You're welcome. As your reyuest is solvedm I will close this thread now.
Best regards
Tina
