am 17.05.2021 19:19 - zuletzt bearbeitet am 17.05.2021 19:29 von CommunityTeam
Hello, Support Team!
My contract suppoused to be terminated on 12.06.2021.
Now I don't need to cancel it, need to continue for 1 more year.
Customer number - xxxxxxxxx.
Please, cancel the termination.
Thank you.
Edit: Customer number deleted because personal data / Admin
am 20.05.2021 07:28
Hello Oleg,
thank you for your private message. I have cancelled your cancellation. You will receive a separate confirmation.
Do you have other questions?
Best regards
Tina
am 18.05.2021 09:43
Hello Oleg_Merzlikin
did I understand correctly that we should cancel the cancellation? You want to cancel the cancellation?
We have to re-legitimise your data. Send me a private message with your name, full address, customer number and date of birth. Important: Afterwards, report back here in this thread.
Please make sure not to send the data publicly here in the thread.
Regards
Grit
am 18.05.2021 13:28
Hello, Grit,
yes, correct, the contract should continue.
Personal data you requested are sent in private message.
Thank you.
am 19.05.2021 20:06
Hi, Grit,
Have you got my personal data?
Thank you.
am 20.05.2021 07:28
Hello Oleg,
Best regards
Tina
am 20.05.2021 09:07
Hello, Tina,
thanks for update.
I can see everything is fine now. No more questions.
Thank you for your help.
am 20.05.2021 10:49 - zuletzt bearbeitet am 20.05.2021 12:14 von Tina
Hello, Tina,
just received a letter,
in the list of products are
*** Vodafone GigaTV Cable
*** Vodafone TV Connect
TV was canceled long time ago, I don't need it. Please, leave only internet contract active.
Thank you.
Edit: Deleted personal data.
20.05.2021 12:16 - bearbeitet 20.05.2021 12:22
Hello Oleg,
this was a mistake. The tv contract has been terminated and will not be reactivated.
Best regards
Tina
am 20.05.2021 12:31
Hello, Tina,
thank you for update.
Appreciate your help! 🙂
