am 15.11.2019 09:49 - zuletzt bearbeitet am 15.11.2019 13:37 von Mav1976
Hi! My internet has been out the last 24 hours. In the log it says CHAP authentication failure. What do I need to do to fix it? My account number is ***.
*** @Shane3in1, personal data removed, thread moved from Gewinnspiele to DSL ***
am 15.11.2019 10:07
am 15.11.2019 15:56
Hello Shane3in1,
do you use DSL or cable?
Best regards
Moni^mmk
am 15.11.2019 16:44
I have DSL. Thank you for your help.
am 15.11.2019 18:27
i have tried putting the setup code back into the router and it fails every time I try. Seems if my access to the system has been messed up.
am 16.11.2019 00:10
issue has been fixed. Thank you.
am 16.11.2019 17:29
Hi Shane3in1,
thanks for your feedback.
I'm glad you can use your DSL connection again.
As your issue has been solved, I close this thread.
Regards,
Jens
