am 16.06.2021 12:49
Hi, my easy box 804 router is not working properly. I would like to replace it. Which data should I share?
Best
am 17.06.2021 11:13
Hey Argonaut44,
may I ask you at first which problem you have with the easybox?
Did you try a factory reset?
Best regards
Norman
am 17.06.2021 22:57
Hi!
The problem that I am losing internet wi-fi signal every 1.5 hours (followed by a 5 minutes reactivation period). It happens on different devices connected to the easy box 804. I tried to turn off/reset the device but the problem persist.
am 19.06.2021 18:25
Hey Argonaut44,
if the problemes survive even a factory reset, its most likely a defect of the router.
If a rented router or still under guarantee im happy to swap it.
Could you please send me a private message with your customerinfo (customernumber,password)
Therefore please click on my name/avatar -> then the big red button on the right side.
Cheers,
Andre
