am 24.01.2021 18:54
I found out that I apparently lost my own copy of the contract for Kabel Deutschland, is it possible to request a copy to be sent to me again?
Regards,
Daria
am 24.01.2021 19:52
You might have a look at the "Mein Kabel" self-service portal - there is an item called "Meine Dokumente" (My documents) that contains all the documents that have been sent to you in the last 12 months - in case you made your contract in that time, the information should be there.
am 24.01.2021 19:52
am 24.01.2021 19:56
@reneromann , thanks, I checked there and what I can find is the document called "Auftrag" and tbh as a not so good German speaker I am not sure if this is the document I'm looking for 😄 I am expecting something called Vertrag. Do you know if there is a difference?
am 24.01.2021 20:02
That should be the one that you are looking for.
That "Auftrag" can be translated as "Request for a contract" or in that case it is more likely to be understood as reply to your request for a contract.
am 24.01.2021 20:03
Got it, thanks a lot!
am 26.01.2021 11:43
Hello DariaKameneva,
I already have your customer data. Do you want the copy by e-mail? If so, send me your email address in a private message.
Best regards
Tina
am 27.01.2021 21:13
Hi DariaKameneva,
I placed your mailaddress in your customer data. You'll get a message to verify your address.
After done so, please respond here again. Thanks.
Regards
Stephan
am 28.01.2021 17:42
Thanks, it's done now.
am 29.01.2021 19:57
Hi DariaKameneva,
I'll send you another copy of your contract. Btw. the document you found in your customer portal was the right one.
Not bad for a "not so good German speaker".
Regards
Stephan
