am 09.08.2018 17:43
Hello,
since two weeks I have very bad WiFi connection, especially in the evening. Signal is not stable. When I connected my laptop via cable (Ethernet) internet works much better. Do you know what can I do with this problem?
Thanks.
am 13.08.2018 15:38
Hi testvb,
have you already tried changing the WLAN radio channel? You can do this via the router menu. How far away are your devices from the router?
Kind regards
Marcus
am 15.08.2018 20:52
Hi Marcus,
unfortunatly I can't access router menu, I tried different user names and passwords, but without any success.
How far away are your devices from the router? - 1m.
am 20.08.2018 08:40
Hello testvb,
you can see the access data on the bottom of the box itself. Access via https://kabel.box. If this still does not work, please carry out a factory reset.
Greeting Fred
27.09.2018 09:46 - bearbeitet 27.09.2018 09:47
Dear Fred,
I tried to change WLAN radio channel and it little bit helped but connection was still not stable, but from yesterday WiFi connection started to be so bad and nothing helps anymore. I even was not able to login to my Hitron anymore, only it's restarting helped. I'm super tired from such internet and that I can't use WiFi, I always need to use cable to connect to router.
My feeling is that Vodafone doesn't have any interest to help me with my problem 😞
I have this problem and with my mobile devices and tablet. But with them I can't use cable.
Could you be so kind to tell me how we can resolve my issue?
I'm paying money for the contract that includes router with WiFi, and WiFi I can't use at all!!!!!
Best regards,
am 02.10.2018 08:49
Hi testvb,
at first: stop spamming with new threads and PNs we did not ask for. You have to wait for an answer like everyone else. Since Freds last answer you waited 1 month for a response, so please be a bit patient, when we do not reply within a short time.
I will replace your Hitron. Please send me your name, address and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
am 10.10.2018 07:57
Dear Marco,
since August I called to Vodafone support team couple of times (without writing here), after you suggested here to change WLAN radio channel, and again and again ideas were to change WLAN radio channel, I explained by phone call that this didn't really help and your colleagues suggested to call to Hitron manufacturer, that is not a solution of my problem.
I was waiting enough and an answer like: stop spamming, is not customer friendly behaviour. I expect at least an apology from your side that from the beginning your team tried not to solve KNOWN problem with Hitron router (you have already enough such topics here and not only from me), but pushing me to do unhelpfull actions.
So I hope that I will be able to tell you thanks after you change my router. And I have sent all my deatils in PM.
Best regards.
am 16.10.2018 14:31
Hi testvb,
the new router will arrive within the next days. Pleace replace it. It will connect irself without any data-entry. Please send the other router back with the return-paper in the package within 14 days.
Kind regards
