am 29.08.2018 21:34
Dear VF Team,
Since I have switched to EasyBox 804 (from EasyBox 904 xDSL), I am having intermittent WiFi problems. If one device is on Youtube, then other devices are unable to surf or connect to any website.
Please help!
-Aniket
am 30.08.2018 14:22
Hi aniket2812,
here to find several tipps for optimizing your WIFI: Alles zu WLAN
If the WIFI signal of the free EasyBox 804 is to weak you might use WIFI repeaters or, if possible, powerline adapters.
The EasyBox 904 should also be compatible with your new DSL connection.
Regards,
Jens
