Menu Toggle
Aktuelle Eilmeldungen:
Mobilfunk: Mobile Telefonie und Daten 2G/3G/4G im Gebiet 88212 Ravensburg
Kabel: Ausfall Internet und Telefon im Raum Berlin in den Abendstunden
MeinVodafone: Ausfall aufgrund geplanter Wartungsarbeiten
Mein Vodafone App:  Log In aktuell nicht möglich
Mein Vodafone App:  Vodafone Pässe können nicht mehr kostenlos geändert werden bei iOS
E-Mail: Neue SPAM-Welle bei Vodafone & Arcor Mail-Accounts.
Close announcement
Internet-Geräte
Siehe neueste
Problems with Arris TG3442DE router
Highlighted
Hello,
Quite often (every other day) the download speed will go below 10-15 Mbit/s (from 100 Mbit/s) or there will be no internet at all. Usually restarting the router from the settings (192.168.0.1) would fix the problems. But sometimes 192.168.0.1 is not even accessible and a hard reboot (power off) is required.
Does the router need replacement or a firmware update would remedy these issues? The current firmware version is AR01.01.117.01_091718_70.PC20.10, which seems to be almost 2 years old.
Kind regards,
Georgi
9 Antworten 9
Highlighted
Moderatorin
Hello zverock,
the signal looks good so far. Please do a speedtest while using a direct ethernet connection and send the result with the time stamp. Have you tried making a factory reset?
Kind regards,
Alles Easy How To Hilfe !
Highlighted
Hello Claudia,
I cannot do an ethernet connection speedtest at the moment as we have just ultrabooks here and they don't have ethernet ports (or adapters). The lower speed and no internet problems occur almost every other day and apply to all devices (laptops, phones, tablets) regadless of the distance to the router. After a soft or hard restart everything is back to normal like it is now.
I haven't tried a factory reset. I'm pretty sure it's a firmware issue as a hard reboot is required sometimes. How can we get the latest firmware?
Kind regards,
Georgi
Highlighted
Had to do a hard reboot again about 48 hours after the last restart.
Highlighted
Same Problem here, Same Router, Same FW...
I'd like to have a FW - Update, too.
Ist das denn möglich, liebes Vodafone-Team? OSmiley (fröhlich)
Highlighted
Moderator
Hi zver0ck,
I can only ask for an update at our specialist department.
Please send me your name, address and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
Highlighted
Hi Marco,
PM sent. Thank you!
Kind regards,
Georgi
Highlighted
Moderator
Hi zver0ck,
The signal values look great. My guess is the modem's not working properly. I'd like to replace it free of charge, all right?
Kind regards
Highlighted
Hi Marco,
That would be great, thank you!
Kind regards,
Georgi
Highlighted
Moderator
Hi zver0ck
the new modem will be on its way to you shortly. You can exchange it directly. It logs on alone. You can then send the old router back to us within 14 days free of charge with the return slip.
Kind regards
