am 05.11.2020 09:32
Hello,
My router keeps restarting at least once a day randomly and it is becoming pretty annoying.
Is there a solution to this (apart from changing device?)
Thanks,
Filippo
am 10.11.2020 08:58
Hello fberga,
which router modell do you use and in which federal state do you live? Did you replace the coaxial cable already?
Kind regards,
am 16.11.2020 20:43
Hello Claudia,
thanks for your answer. I live in Berlin and I have a Vodafone Station TG3442DE. I haven't replaced the cable but the condition seems pretty good and it has only few months (it was the one in the package with the router).
The situation seems getting worse and worse since now it restarts at least three time a day. What am I supposed to do?
Thanks,
Filippo
am 19.11.2020 15:33
Hello fberga,
I would like to check your access, please send me a private message that includes your name, address, the customer number and the birth date of the contractual partner. Reply here again afterwards. If you can check another coaxial cable in the meantime that would help :).
Kind regards,
am 19.11.2020 19:12
Dear Claudia,
Sent a private message with requred data. I will check the cable in the meantime.
Thanks,
Filippo
am 24.11.2020 12:00
Hello fberga,
I see there are still reboots and there are some minor signal problems. Did you replace the coaxial cable already?
Kind regards,
am 25.11.2020 20:11
Hi Claudia,
I bought the cable and will replace it as soon as it arrives. I was wondering if the device in the image below could be the problem instead of the cable.
Best,
Filippo
am 30.11.2020 10:01
Hi Filippo,
sure, this could be possible. What is it like with the new cable?
Kind regards
am 30.11.2020 19:27
Hi Marco,
Today no restarts. Hope this lasts!
Best,
Filippo
