am 27.01.2021 11:09
Hello Vodafone community
Please excuse that my German is not good enough to explain my issue. So I write in English.
I am a ex Unity Media customer and I am using Vodafone Station with 1 Gbps internet.
Recently I bought an Unifi Dream Machine Pro and connected to the LAN port of Vodafone station. But I had some trouble to connect to the UDM Pro from the outside world. Seeme the Vodafone station doesn't support port forwarding.
So I would like to enable the bridge mode for Vodafone station. Does anyone have an idea how to do that? Since I'm not a Vodafone Kabel Deutschland customer but just an ex UnityMedia customer, so I cannot enable this bridge mode using the https://kabel.vodafone.de/ portal right? Please give me some advice. Thank you in advance.
am 27.01.2021 11:27
Just now it is not availible yet.
actual there is no timeline when it is planned.
am 27.01.2021 17:33
Any way I can by pass Vodafone Station? I read there is a cable modem can be used to replace the vodafone station. Where can I buy it?
am 07.02.2021 07:47
Hi AndyJiang
Unfortunately, we can't currently offer the Fritzbox for rent. However, you are welcome to buy your own. You just have to send us the CM Mac and serial number so that we can store it here systemically.
Best regards
Ida
am 07.02.2021 14:48
a private Fritzbox doesn't help because there is no bridge mode any longer
try to configure your DM Pro as exposed host in VF Station or buy a TC4400
regards Robert
am 10.02.2021 09:37
Thank you for your answer. So I can use TC4400 to replace Vodafone Station and set it up in bridge mode, correct?
Best Regards
Andy
am 10.02.2021 09:38
By saying "buy your own", do you mean I can buy a TC4400 to replace Vodafone Station?
Thanks
Best Regards
Andy
am 10.02.2021 11:23
yes you can
and the TC4400 is a modem only, no need for bridge mode
bridge mode is for routers to transform them into a modem
