Behoben Kempten: Ausfall TV und Radio über Kabel
am 12.08.2019 11:34
Habe seid knapp zwei Wochen einen eigenen Kabel Router in Betrieb (FritzBox 6591 cable) und seid dem mehrere kurze Verbindungsabbrüche beobachtet.
12.08.2019 11:30:41 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:30:39 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:30:01 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:59 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:50 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:49 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:41 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:40 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:40 CM-STATUS message sent. Event Type Code: 1; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:38 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:17 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:29:15 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:28:48 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:28:47 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:28:18 CM-STATUS message sent. Event Type Code: 4; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1; 12.08.2019 11:28:18 Lost MDD Timeout;CM-MAC=dc:39:6f:2d:00:09;CMTS-MAC=00:17:10:9a:f4:84;CM-QOS=1.1;CM-VER=3.1;
habe mal aktuelle Mitteilungen der FritzBox zum Zeitpunkt dieser Nachricht eingefügt!
Kanal Kanal ID Frequenz [MHz] Modulation Power Level [dBmV] MSE [dB] Latenz [ms] korrigierbare Fehler nicht korrigierbare Fehler 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 1 146 154 162 602 618 626 642 650 658 666 674 682 690 698 706 714 722 730 738 746 754 762 770 778 786 794 802 810 138 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 64QAM 256QAM 1.2 1.5 0.9 -9.5 -9.3 -8.9 -9.6 -9.7 -10.3 -10.8 -10.4 -11.3 -11.7 -17.8 -18.4 -19.2 -18.4 -20.3 -20.0 -20.5 -21.6 -21.4 -22.0 -22.8 -23.7 -24.4 -25.2 -25.2 1.4 -38.6 -39.0 -38.6 -33.8 -33.4 -33.7 -33.4 -33.4 -33.1 -32.7 -33.0 -32.3 -32.2 -26.9 -26.9 -26.2 -26.6 -25.3 -25.6 -24.5 -24.0 -23.9 -23.2 -22.9 -21.9 -21.1 -20.6 -20.4 -38.6 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 0.32 9 11 0 33876 143767 79760 172851 173047 311948 720454 597455 1709644 1714559 148635 180547 946185 435576 7191689 4430869 26176324 54791281 65959755 128391177 172769201 245043527 144608082 50080887 26847957 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 24 1092 2274650 111787627 206888080 230074875 0
gerade bei den hpohen Kanal nummern treten viele nicht korrigierbare fehler auf (Kanal 24-29)
am 13.08.2019 16:15
Das Problem ist nicht das das Gerät keine Möglichkeit hat Werte auszulesen man muss nur Glück haben das sich die Weboberfläche des Leihgerätes nicht ständig aufhängt oder es nur sehr träge reagiert!
Gebündelte Downstream-Kanäle Kanal Frequenz (Hz) Signalstärke (dBµV) Signalrauschabstand - SNR (in dB) Modulation Kanal ID 1 674000000 49 34 256QAM 1 2 146000000 61 39 256QAM 2 3 154000000 62 39 256QAM 3 4 162000000 61 39 256QAM 4 5 602000000 51 35 256QAM 5 6 618000000 50 35 256QAM 6 7 626000000 51 35 256QAM 7 8 642000000 50 34 256QAM 8 9 650000000 50 34 256QAM 9 10 658000000 49 34 256QAM 10 11 666000000 49 34 256QAM 11 12 138000000 62 39 256QAM 12 13 682000000 49 34 256QAM 13 14 690000000 49 34 256QAM 14 15 698000000 42 28 64QAM 15 16 706000000 42 28 64QAM 16 17 714000000 42 27 64QAM 17 18 722000000 42 27 64QAM 18 19 730000000 40 26 64QAM 19 20 738000000 41 26 64QAM 20 21 746000000 39 25 64QAM 21 22 754000000 39 25 64QAM 22 23 762000000 39 25 64QAM 23 24 770000000 38 24 64QAM 24 Gebündelte Upstream-Kanäle Kanal Frequenz (Hz) Signalstärke (dBµV) Modulation Symbolrate (ksps) Kanal ID 1 52200000 107 64QAM 5120 1 2 36200000 107 64QAM 5120 2 3 45800000 107 64QAM 5120 3 4 58600000 107 64QAM 5120 4 Signale Kanal ID Fehlerfreie Codewörter Korrigierbar insgesamt Nicht korrigierbar insgesamt 1 68154583 5153 3 2 61819398 10 0 3 61784426 74 0 4 61821741 5 0 5 61823455 261 0 6 61780857 382 0 7 61787825 148 0 8 61789583 575 0 9 61825166 608 7 10 61791795 1091 0 11 61794627 2278 0 12 61799169 8 0 13 61779957 8139 0 14 61796880 6046 0 15 46348093 3445 0 16 46333669 2154 0 17 46334499 19586 0 18 46330633 7491 0 19 46224924 129920 0 20 46240370 115628 0 21 44464788 1894889 0 22 43886458 2474872 0 23 41796865 4566102 0 24 32895976 13469952 0
so endlich nach einer halben std habe ich die gesuchte Seite der Weboberfläche gefunden
am 13.08.2019 16:47
Dies sind aktuellere Werte nach einer std vorhandener Internetverbindung
Gebündelte Downstream-Kanäle Kanal Frequenz (Hz) Signalstärke (dBµV) Signalrauschabstand - SNR (in dB) Modulation Kanal ID 1 674000000 49 34 256QAM 1 2 146000000 62 39 256QAM 2 3 154000000 62 39 256QAM 3 4 162000000 61 39 256QAM 4 5 602000000 51 35 256QAM 5 6 618000000 50 35 256QAM 6 7 626000000 51 35 256QAM 7 8 642000000 50 34 256QAM 8 9 650000000 50 34 256QAM 9 10 658000000 49 34 256QAM 10 11 666000000 49 34 256QAM 11 12 138000000 62 39 256QAM 12 13 682000000 49 34 256QAM 13 14 690000000 49 34 256QAM 14 15 698000000 42 28 64QAM 15 16 706000000 42 28 64QAM 16 17 714000000 42 27 64QAM 17 18 722000000 42 28 64QAM 18 19 730000000 40 26 64QAM 19 20 738000000 41 27 64QAM 20 21 746000000 40 25 64QAM 21 22 754000000 40 25 64QAM 22 23 762000000 39 25 64QAM 23 24 770000000 38 24 64QAM 24 Gebündelte Upstream-Kanäle Kanal Frequenz (Hz) Signalstärke (dBµV) Modulation Symbolrate (ksps) Kanal ID 1 52200000 107 64QAM 5120 1 2 36200000 107 64QAM 5120 2 3 45800000 107 64QAM 5120 3 4 58600000 107 64QAM 5120 4 Signale Kanal ID Fehlerfreie Codewörter Korrigierbar insgesamt Nicht korrigierbar insgesamt 1 134155971 11633 3 2 127823815 243 2717 3 127788947 275 2692 4 127826394 210 2637 5 127830374 664 0 6 127787726 847 0 7 127795222 326 0 8 127796340 1362 0 9 127831536 1381 7 10 127797817 2538 0 11 127798297 5264 0 12 127803647 185 2292 13 127776923 18041 0 14 127795409 13654 0 15 95848114 8040 0 16 95834872 5011 0 17 95809807 48333 0 18 95824983 17381 0 19 95564284 294787 0 20 95597654 262303 0 21 91632850 4230782 0 22 90303844 5561416 0 23 86042176 9824722 0 24 66929539 28939749 0
am 13.08.2019 17:55
Das gleiche wie bei der 6591. Völlig aus der Toleranz.
am 13.08.2019 18:20
am 14.08.2019 17:21
Hallo kinghol,
danke Dir.
Schick mir bitte Deine Kundendaten zu dem Kabelanschluss per PN zu.
Wenn es Dir möglich ist, lass bitte das Leihgerät am Anschluss dran.
Jens
am 15.08.2019 19:07
Hallo kinghol,
erneut Danke, dass Du den Kabelrouter dran gelassen hast.
Leider seh ich nicht, wo es vielleicht zur Beeinträchtigung kommen könnte.
Kann ein Techniker zu Dir und auch an die Hausanlage direkt bei Dir ran?
Jens
am 15.08.2019 20:23
Ist ein zwei Familienhaus! Direkt am Hausanschluss Verstärker ist die t-Brücke für den Tv Anschluss von meinem Vater und der andere geht auf die Technik von Vodafone!
Also ja alles begehbar und direkt an der Haustür erreichbar.
am 16.08.2019 19:42
Hi kinghol,
was meinst Du mit T-Brücke?
Ist das mal von einem Techniker installiert wurden?
Oder mach ein Bild und häng es an eine Antwort an. 😉
Jens
