CH7466CE WLAN problems
Greenta
Hello,
I have the router "CBN CH7466CE",  Firmware version "4.50.21.4", and it has WIFI connectivity problems, I
have to restart it quite often and I can’t use the 5GHz WIFI at all.
Basically, it is difficult to connect to it and the speed is dropping to very low.
It is fine if I use Ethernet cable, but the WIFI is not working most of the time.
I have had this router for three years.
5 Antworten 5
Ex-Moderator:in
Ex-Moderator:in
Hello,
welcome, i can take a look at the connection 🙂 Will you send me your customer data via private message?
Then please let me know in the post when you have the data.
Regards
Hello Mr. Tobias,
Thank you for the reply.
I've sent the customer data in private as requested.
kind regards
Martin59
Hi Greenta,
We need your full name, address, date of birth and customer number via  PN .
Best regards, Martin
Hello Martin59,
Thank you for your reply.
I've sent the details via PN as requested.
Kind regards
Wallace
Ex-Moderator:in
Ex-Moderator:in
Hi Greenta,
can you please initiate a factory reset via the router user interface?
Regards
Wallace
